Showroom 6DOF Build (Bodine Motors, Sabertooth, FlyPT Mover)
Discussion in 'DIY Motion Simulator Projects' started by BondeX, Mar 10, 2016.
  1. BlazinH
    16,691Coins
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    yes a gusset would help but i still dont think that will be enough. the motors are 13lbs by themselves. it will oscillate at the least.
  3. Nick Moxley
    Your the guy doin the welding....figure it out.....lol:cheers
    • Funny Funny x 2
  4. Nick Moxley
    @BlazinH ;)
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
  6. BlazinH
    16,691Coins
    Yes, I saw that too! But while it is friendly offer, who likes to take something to someone else to do it for them when they don't have too? Also, just because they both live in Michigan doesn't necessarily mean they live close to each other.
    The facts are that although you wouldn't want to support motors by the motors only, he just needs to stabilize them a little bit. So 6 wood blocks and $12 worth of hose clamps will take care of the problem in short order without all the hassle. ;)
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    Thanks @BlazinH. he does live very close. 10 minutes. We've talked on the phone also. So it's not impossible. But I also understand doing it yourself. Try the wood if that doesn't work gimme a shout.
    • Friendly Friendly x 2
  8. poman
    poman Active Member
    154Coins
    maybe use a torque seal paint to see if they moved, like in aeronautics, and do a walk around before playing, like if it was a plane lol!! that is what i though of doing at first to see how it behaved.
  9. Nick Moxley
    Motor's would need to be "loaded" with a driver to see anything really.
    • Agree Agree x 3
  10. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Ok, so finally got all the electronics done and tested each MM & PS with SMC3. Mounting rods are done and feel very sturdy, just need to apply loctite on the nuts and ball joints. Platform is very sturdy and has no play whatsoever.
    Need to solder 4 Hall sensors and I should be ready to test motion.
      409.3 KB
      928
      296.4 KB
      915
      296.5 KB
      904
      272.9 KB
      929
      482.7 KB
      948
      407.2 KB
      963
      451.1 KB
      959
      338.1 KB
      953
      320.9 KB
      956
      199.9 KB
      939
      312.6 KB
      938
      237.7 KB
      936
      254.9 KB
      903
      277 KB
      927
      258.8 KB
      920
      229.8 KB
      949
      178.8 KB
      902
      199.9 KB
      908
      281.3 KB
      966
      305.6 KB
      854
    • Like Like x 10
  11. SeatTime
    Another 6DOF is born:thumbs. I hope testing goes well.
  12. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thanks @SeatTime, i hope so too.
    Need to read up on axis assignment and defining DOFs :(
  13. SilentChill
    20,601Coins
    We need videos !!! :D
    • Optimistic Optimistic x 1
  14. BondeX
    EE
    Michigan, USA
    1,501Coins
  15. GR88
    GR88 Member
    M.E Student
    USA
    644Coins
    Your control box looks amazing. I hope I can get mine that neat when the time comes. Can't wait to see the progress!
  16. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thanks @GR88, Its nothing compared to what I have seen on this forum. I feel my setup is pretty basic.
    I am trying to figure out how to assign AXIS. I am looking at @vulbas's assignment and I am wondering how did he come up with these values and why are some different for lets say Roll, for Axis 1 & 2. Is his assignment a good starting point? Axis 1 = Motor 1, Axis 2 = Motor 2......?
    [​IMG][​IMG]
  17. SeatTime
    Good start point, but unfortunately it will be similar, but slightly different for every Stewart Platform sim. Can depend on how the axis's are numbered, direction of motion for each motor, which end you call the 'front' of the sim and also the geometry of the sim, as we are not using 6DOF maths - (which is why different % are also used to adjust for non linear movement) Note you will not get sway and surge perfect, but in reality it does not really matter. From looking at his setup Axis 1/2 are at the back and 3/4 and 5/6 are left/right.
    • Informative Informative x 3
  18. BondeX
    EE
    Michigan, USA
    1,501Coins
    Well since my sim is an hour away, I needed a way to understand how SimTools Axis assignment and Interface worked. I built a mini replica of my 6DOF and used two Arduinos/Interfaces.
    On the actual sim do I need to have Startup Output and Shutdown Output populated?
      369.7 KB
      769
      369.5 KB
      760
  19. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    just started playing around with simtools on my 6dof, my layout is the same as your replica. i used the above dof assignments from vulbas as a starting point and everything worked pretty much spot on straight away, which was a nice suprise!
    as seattime said some of the movements are not completely flat ( we need to wait for simtools 2 and math plugin for this??) but its pretty much there.
  20. BondeX
    EE
    Michigan, USA
    1,501Coins
    Alright, so I finally tested motion and so far so good. Just debating whether I should mount my Obutto Ozone on top of the platform.
    • Like Like x 6
