Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    I took the scrap pieces from the base along with some re-purposed bed frame rails to create my motor brackets. I'll drill them tomorrow before I mount them to the base.
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    Got the old sim out, the new frame in place. I mounted the brackets and motors. I'll start on the cockpit next.
  3. Historiker
    9,205Coins
    That's it! I am coming over! :grin
    (And bringing those shoes)
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    Wife is gonna complain about the bare osb. I can already hear it. "Are you just gonna leave it like that". It will have to be covered. Maybe I'll do some indoor/outdoor after I'm done welding. Yeah we won't share that I was welding in the house she won't like that either. Maybe she's right in calling me a 45 year old teenager. Oh well.
  5. Historiker
    9,205Coins
    Looks good to me :) I just slapped a coat of paint on the concrete in my man cave and called it good. My wife keeps asking if I wouldn't rather put some flooring down.
    I still kick myself for not buying up some of those motors when they were super cheap.
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    Wish I would have bought more. I could have used them for a few other jobs too. I would have grabbed a few more 50amp psu's also. I paid like 15.00 a piece for those.
  7. Nick Moxley
    you can usually find the Dell 2750's for 10-12.50$ when you look around.....I think the max I paid at any point was 16$ a pop.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
  9. Nick Moxley
    Whats the Weight limit your going for Bruce ? Cant exactly say that frame looks very light per say....And i would assume Every lb counts at this stage.
  10. RacingMat
    21,082Coins
    it looks very promising!
    keep practicing the welding: maybe increase the intensity or slow down your speed in order to melt more the metal.
    here you can see through the helmet
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes I'm more of a grinder than a welder lol. I'll touch them up and grind. A better welder with bigger rods would help. These little rods wanna burn thru easy.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    If watching videos made you good I'd already be an ace. I subscribe to weldingtipsandtricks on YouTube, now that guy is badass. If you like the welding videos this guy uses pov cam too.
  13. Historiker
    9,205Coins
    I have watched his as well, I am no better but that is my fault not the instructor :)
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    20160523_130433.jpg @Nick Moxley, I still have to add the pedal area. I should be able to keep itunder 100lbs with hardware. We'll see if I'm forced to do some hole saw weight loss. I weigh about 150, so if total weight is less than 250lbs it should be ok.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    Soon it won't be bucket powered.
    • Funny Funny x 3
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    Work keeps getting in the way of my sim building. It's still bucket powered. I'll try to get the rods made later after work. Then I can start on the control electronics.
  17. Historiker
    9,205Coins
    Keep us updated; after you are done I will come over for a "stress test" [insert evil laughter here]:cool:
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    Seat is still not attached as I'm still lacking a motor suitable for the surge application. The bodines come in at 13lbs each without any hardware. That's just too much weight. I really haven't looked as I've been building and working. Also on the to do is levers and rods, electronics, feedback system, extending the wheel upright closer to the driver, paint base, end caps for the 1x2 steel, diamond plate for foot area, monitor mounts............
    In short there's still and bunch of crap to do. I'm trying to be as close as possible for MIS week on IRacing. That's the second week of June so maybe I need to give up on sleep. An hour or two Of building each day is not enough.
    153,938Coins
    +11,158 / 57 / -2
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    Under 7 lbs yes this would be much better to.
