Commercial 3DOF Motion Platform Stepper Motor development questions
Discussion in 'Commercial Simulators and Peripherie' started by marc79, May 31, 2016.
  1. marc79
    marc79 Member
    482Coins
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    I don't think the motors will be strong enough for a motion platform, a seat mover should be fine but not a platform.
    At 13NM holding torque I doubt they will have the strength to survive fast directional changes on a full platform motion simulator. 13NM equates to around 132kg for a 1cm lever arm. 3cm is probably the minimum you would want to go for and with that length the motors can only hold 44kg.
    Ideally you would want a motor that has been geared down so that it has greater torque. Those steppers appear to have a gearbox option.
    One other point is that I don't think that anyone has set up a motion simulator with a stepper motor as they require continual pulses to get them moving as opposed to the more common method of using servomotors. (simple DC motor with feedback). So i am not sure if anyone has coded for the use of stepper motors.
    Another maybe non issue is that stepper motors might be uncomfortable especially in low speed motion as you would feel vibrations (each step), especially in the motors listed as the step angle is 1.5 degrees (quite coarse). A grearbox would greatly reduce the vibrations felt.
    153,788Coins
    +11,150 / 57 / -2
    I agree with @Alexey, the stepper motors are not really that powerful, same with the PSUs, and using steppers may be a complicating factor compared to DC motors.
  4. marc79
    marc79 Member
    482Coins
    We are using gear boxes with it, that will supply 50nm, I was asking if the items like the driver and PSU can be used for making the platform @noorbeast @Alexey
  5. marc79
    marc79 Member
    482Coins
  6. marc79
    marc79 Member
    482Coins
    your right it is noisy but was that spinning on fast RPM?
  7. marc79
    marc79 Member
    482Coins
    if anyone can suggest a better motor to use with the gear boxes i provided then, the Flange needs to be 86*86 square.
  8. marc79
    marc79 Member
    482Coins
    @noorbeast about coding, are they saying I wont be able to simulate the games and software?
    153,788Coins
    +11,150 / 57 / -2
    You will need code to interface with SimTools and control steppers. SimTools can take care of the game side of simulation.
  10. marc79
    marc79 Member
    482Coins
    153,788Coins
    +11,150 / 57 / -2
  12. marc79
    marc79 Member
    482Coins
    @SeatTime who can I get help in the programming part, I still want to move forward with it, as it has been calculated by the engineer. The noise wont be so bothersome for the fact it will be outside
  13. marc79
    marc79 Member
    482Coins
    Ok I decided to go with servo motor instead, let me know if this would be the easiest thing to do then? @noorbeast
  14. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @marc79 Geez mate, don't you get it? Your "going where no man has gone before" so to speak.
    Every reply from the gurus of the forum so far has been negative. Go for it by all means, but realize it's useless asking questions about a subject that has hardly been explored. That's my opinion anyway. At least your slowly building up some coins!! II
    ps I even started to wonder if you and you're engineer are fair dinkum, Sorry!!
  15. marc79
    marc79 Member
    482Coins
    Im asking about servo motors now, not stepper motors, so your saying no motor but DC motors have not been tried before?
  16. noorbeast
    153,788Coins
    +11,150 / 57 / -2
  17. marc79
    marc79 Member
    482Coins
    its fine what I can do is make a smaller platoform using servo motors and experiment with that first, I also found me a arudino programmer to help me with the project @noorbeast. I found out servo motors are the best motors to use for motion platform. Seems like no one here has experience with motors. I might show the project once finished, but I am not getting enough here to share with everyone. if this works I would had made a cool 3DOF for pretty cheap. oh and it helps I have a brother in law that works with metals
  18. Nick Moxley
    lol funny guy.
  19. marc79
    marc79 Member
    482Coins
    yeah because all I got was negative feedback on stepper motors and when I decided to change motors to Servo motors I get hit with no info again. I would be happy to share if I can get some feedback here. The servo motors im getting now with gearbox, servo driver and cables are costing me 1200 usd and give 65NM of torque on each motor. The engineer from the motor company they have DC motors but servo motors are much better for it as going forward and reverse.
  20. marc79
    marc79 Member
    482Coins
