Miniature Simulator 3 Dof
Discussion in 'DIY Motion Simulator Projects' started by MagicMike, Feb 5, 2014.
  1. MagicMike
    MagicMike New Member
    961Coins
    I purchase my arduino 2560 mega , 3 x l293 shields and 3 step motors 28byj-48 .
    I install the sdk and the arduino on my windows pc and everything is ok
    I plugin my board and i play with some leds and worked fine.
    Now I want to connect the 1 stepper motor to my l293 shield and to start to do some movement
    The problem is i dont know the pins and the wiring yet!
  2. bsft
  3. prilad
    Dubna, Russia
    9,658Coins
    3DOF, DC motor, Arduino, 4DOF
    Look here - all info about l293 shields.
    http://learn.adafruit.com/adafruit-motor-shield/using-stepper-motors
    • Useful Useful x 2
  4. MagicMike
    961Coins
    This is what i need this moment. Next step is to write the code for my arduino to receive the data from SimTools. Thank you @prilad
  5. eaorobbie
    20,480Coins
    Look at my Servo example you can use that to capture the right info from SimTools just need to erase the servo stuff and place the stepper stuff in , easy one.
  6. MagicMike
    961Coins
    thank you very much , great forum :) Can you show me where is your source code mate?
  7. Dini200
    Dini200
    @MagicMike
    hi how do you solve it ? I also used L293
    Can you show me where is your source code ?
  8. SeatTime
    Hi @Dini200 , date on last post from OP is 8 Feb 14 - don't like your chances on getting a response..
  9. Dini200
    Dini200
    @SeatTime
    hii, im sorry
    whether there is a thread that discusses L293 drivers for 2dof ?
  10. SeatTime
    No reason to be sorry, I was just pointing out that the last post was over 2 years old and the OP is likely not active. I'm not aware of anyone using them on this site in regard to driving a simulator. I guess you have checked out the links recommended further above?
  11. Dini200
    Dini200
    @SeatTime thanks for the help, I 'm try in my arduino .
    I 'm trying to find the same thread to the low cost motor driver
  12. marc79
    marc79 Member
    482Coins
    I found me an aurdino programmer, I was originally going to use step motors but people claiming there too noisy, so I went with servo instead
