2DOF Arduino Moto Support needed!
Discussion in 'DIY Motion Simulator Projects' started by steve price, May 11, 2016.
  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,357Coins
    So now you have the sliders hooked up does it work with windows SMC3Utils?
    Also you are taking a risk using alligator clips on the MM drivers. If they accidentally touch and short the outputs you could easily blow the drivers.
  2. Pit
    30,501Coins
    Try Axis output instead of forces. Despite of this as far as I can see the Axis Assignments are wrong. Anyway pictures and screen shots help us more if we should help you.
  3. steve price
    steve price New Member
    essex england
    264Coins
    3DOF, Arduino
    Hi all,
    We have made some good progress with our platform, I will attach a video that should show the stage we are up to and our settings in simtools.
    The circuitry looks fine and SMC3 appears to be doing what it should do bringing the pwm line down to the target line.
    Simtools doesn't seem to be talking to it though, and we think we have missed something critical in our setup.
    We did not win the competition back in June but were given a bit of recognition for the design of our build. We are going to continue nevertheless as the students have really got a great load of experience and fun from the project.
    Please let me know if you have any advice on the next steps for our build!
  4. steve price
    essex england
    264Coins
    3DOF, Arduino
    152,971Coins
    +11,115 / 56 / -2
    It is hard to read settings from a video, so can you please post all settings as pictures.
  6. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  7. EntonoX
    EntonoX Member
    Full Stack Developer
    The Netherlands
    122Coins
    If you are using SMC3 code in the arduino;
    1) with the SMC3utils each actuator works? yes -> problem in simtools setting, no -> arduino communication / code problem
    2) If you use SMC3 code, as above mentioned you have the interface settings wrong, please change and try again.
