Trying to implement the project.
Discussion in 'DIY Motion Simulator Projects' started by testlab, Jun 3, 2016.
  1. testlab
    testlab New Member
    33Coins
    Hello! I'm from Russia) My English is very hard !!! Mutko (s) :)
    Trying your hand at building a simulator in the Arduino.
    Please do not blame) As far as I correctly translated the rules. I need to collect 250 coins that would test the program simulation.
    At the moment, I bought fee monster motor driver. I beg your Arduino now have a response from the variable resistor.
  2. testlab
    testlab New Member
    33Coins
    wiper motors were purchased from Russian truck KAMAZ engine number 16.3730. 24 volts.
    Already it has igorovogo frame of the chair.
    Now we cook the bottom part of the frame where it will be attached to the chair hinge.
    153,938Coins
    +11,158 / 57 / -2
  4. testlab
    testlab New Member
    33Coins
    Hello! Thank you suggested about LFS!
    Put SIM Tool. Launched Output Testting all work response to the engine 2. But in a game LFS nothing works. The game downloaded from the official site.
    Game LFS need additional patches? Thanks in advance!!!
    153,938Coins
    +11,158 / 57 / -2
    Are you patching the game for motion: http://www.xsimulator.net/simtools-game-manager/#Patching-a-Game-for-Motion
  6. Pit
    30,510Coins
    Hello, LFS is patched by default. Please upload pictures and screenshots of SimTools etc.
  7. testlab
    testlab New Member
    33Coins
  8. Radioproffi
    Lviv
    1,677Coins
    Привет, как ты планируешь использовать движки от камаза (24В) с МонстрЩитами, если он расчитаны до 16В?
    How do you plan to connect the gear motor (24V) to the Monster Moto Shield, because it is rated to 16V?
  9. testlab
    testlab New Member
    33Coins
    Привет) Я подключал вроде работают шустро (уже почти собрал стенд сниму видео как работает)! Если будет не хватать то поставлю Motor Driver BTS7960 43A .
    Просто сначала купили Monster Moto Shield а потом подвернулись моторы почти даром)
    Hello) I connected like working smartly (almost assembled stand shooting video how it works)! If you will miss then put Motor Driver BTS7960 43A.
    Just bought the first Monster Moto Shield and then turned up the engines for next to nothing)
  10. testlab
    testlab New Member
    33Coins
    Всем привет! Пришли мне тут драйвера BTS7960 43A подключил по схеме https://www.xsimulator.net/community/attachments/wiring-2-motors-jpg.10925/ выставил в коде моде2. И тишина ((( в ветке вроде у двоих такая проблема но решения так и не увидел( Может кто что подскажет. На Монстре все норм на BTS7960 43A реакции 0.
    Hello! I came here BTS7960 43A drivers hooked on https://www.xsimulator.net/community/attachments/wiring-2-motors-jpg.10925/ scheme put in mode2 code. And the silence (((in a branch like the two had a problem but the solution did not see (Can someone tell me that. At Monster all the rules on BTS7960 43A 0 reactions.
