gtx1080
Discussion in 'Off Topic - All other stuff here' started by f1iceman, Jun 4, 2016.
  1. f1iceman
    - 93Coins
    anyone got a gtx1080 yet and running it :)
    any info what its like :)
  2. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    I'm running one, EVGA 1080FE to be precise...
    What do you want to know..? I'll try and answer but i'm pretty noob :p
  3. GTHQ_koop
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Some benches..
    AC VERSION: 1.6.3 (x64)
    FPS: AVG=108 MIN=71 MAX=137 VARIANCE=5 CPU=77%
    LOADING TIME: 25s
    GPU: NVIDIA GeForce GTX 1080 (5760x1080)
    OS-Version: 6.2.9200 () 0x300-0x1
    CPU CORES: 4
    FULLSCREEN: ON
    AA:4X AF:16X SHDW:2048 BLUR:0
    WORLD DETAIL: 4 SMOKE:3
    PP: QLT:4 HDR:1 FXAA:0 GLR:4 DOF:4 RAYS:1 HEAT:0
    And here did I come from:
    AC VERSION: 1.3.4 (x64)
    FPS: AVG=61 MIN=24 MAX=105 VARIANCE=0 CPU=50%
    LOADING TIME: 30s
    GPU: NVIDIA GeForce GTX 970 (5760x1080)
    CPU CORES: 4
    FULLSCREEN: ON
    AA:4X AF:16X SHDW:1024 BLUR:0
    WORLD DETAIL: 2 SMOKE:2
    PP: QLT:5 HDR:1 FXAA:0 GLR:5 DOF:0 RAYS:1 HEAT:0
    And one with PP off
    FPS: AVG=110 MIN=20 MAX=144 VARIANCE=6 CPU=77%
    LOADING TIME: 52s
    CPU CORES: 4
    FULLSCREEN: ON
    PP: QLT:4 HDR:0 FXAA:0 GLR:4 DOF:4 RAYS:1 HEAT:0
  4. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    I got a MSI one, Play AC with HTC VIVE.
    it goes 44.7 FPS in VR view, 120 FPS in single monitor.
    I had tried to turn on 4K DSR, it looks like nothing changed in my eyes.
  5. f1iceman
    - 93Coins
    have you tried it single monitor yet to see the frames you get?
    im trying to find out what it will do for the rift n vr have you got your comp spec too :)
    this could be very usefull in fo at this stage as your using assetto corsa which most play and love on here :)
  6. f1iceman
    - 93Coins
    whats the rst of the comp spec to get that.
    seems low to me compared to the above
  7. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    Intel 6700K 4Ghz
    Nvidia GTX1080 (msi)
    32G RAM
    500G SSD
    3T HDD
    Blu-Ray combo
    700W POWER
    Res 1080p,(i dont have 4k monitor)
    PP off,(remove fog in VR)
    Anti Alias off,(UI got error with AA on)
    Other options gose max
  8. GTHQ_koop
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    No, haven't tried single monitor as I never use only 1 :D
    I could try to do it on Oculus settings as I bought the card for it....But I don't like it and already boxed it again (runs and hides)
    Specs:
    i5 4670K / giga z87x-dh / 8GB ddr3 ram / fsp Aurum 700w / 3x BenQ 2720Z @ 120hz / win 8.1
  9. Nick Moxley
    Interesting to see the 1080 results in comparison to my SLI 980's. Very interesting.
  10. f1iceman
    - 93Coins
    hi nick yes was thinking the same aswell very intresting the diffrent results .
  11. taehoon kwon
    taehoon kwon New Member Gold Contributor
    240Coins
    SCN6, 6DOF
    who did test with 3 ways 1080.?
  12. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    is there any suggest graphic setting for VR?
    I cant make my VIVE run at 90FPS.
  13. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Lower shadows, smoke. set reflections to static
    I got no problem with one 970 in VR (dk2)
  14. Blame73
    8,305Coins
    Not possible (yet)
  15. Blame73
    8,305Coins
    Should you use VR you'd have much worse results, cause you'd use just one 980. Sli is unsupported in AC ( edit: VR).
    There's no point in comparing one 1080 to two 980s in just one games. But you can still think 1080 is s%%t of you want to...
  16. f1iceman
    - 93Coins
    im good with 1 gtx970 with dk2.
    and my comp ain't amazing tbh.
    maybe something wrong i no the lastest driver can be funny on mine so i have gone back abit for now.
    amd fx8350
    8gb ram
    ssd
    gtx970
    oculus recomended usb card.
    tbh since all the new runtimes my dk2 has been awesome :) can noty wait till my cv1 comes as if it gets better than what i have then i'm a very happy lil boy :)
  17. f1iceman
    - 93Coins
    start with every thing low tbh.especially the stuff Blame73 has said.
    you could also set your graphics card back to default too. and change to diffrent drivers. old and new worth a try.
  18. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    I want to make it clear, No SLI support in AC? or SLI supported but not in VR?
  19. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    thx,
    Let me try it this weekend.
    smoke, shadow, mirror
    it kind of shock, that i cant max everything by this PC spec.
    152,445Coins
    +11,078 / 56 / -2
    VR does not yet support SLI, best to use a single powerful card.
