Simtools Arduino pitch problem
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by toanhung, Jun 9, 2016.
  1. toanhung
    toanhung New Member
    - 16Coins
    Hi All
    I use the arduino with moto monster shield and wiper motor. I got 2 problem is somebody can give me a point or how can i fixed.
    1. When I tested in game and when i brake or accell it inverted . Cant seem to find setting to invert it back or how can i do it?
    2. The movement seem to be very minimal . is there anyway i can increase the movement more?
    Any help greatly apricieated
    153,764Coins
    +11,149 / 57 / -2
  3. toanhung
    toanhung New Member
    - 16Coins
    thanks for info, i will play with it
  4. toanhung
    toanhung New Member
    - 16Coins
    do you recommended motor to be attached to bottom seat or shoulder?
    153,764Coins
    +11,149 / 57 / -2
    The shoulder mount gives you good leverage above the COG.
  6. toanhung
    toanhung New Member
    - 16Coins
    here my current setup. i guess i have to weld another pice on top to mount .. thanks[​IMG]
  7. Pit
    30,510Coins
    Do not forget a heat sink to put on the MM
  8. toanhung
    toanhung New Member
    - 16Coins
    yeah just use for testing atm. orginal design was pedal and wheel are move with the seat, but now decide not to and try to make it adjustable too, so more cutting and welding to do LOL.
  9. Lupus
    Lupus New Member
    programmer
    Italia
    476Coins
    hi toung hung , to make your project did you use arduino ? how you programmed it ?
