2DOF Arduino MM
Discussion in 'DIY Motion Simulator Projects' started by toanhung, Jun 17, 2016.
  1. toanhung
    toanhung New Member
    - 16Coins
    On Going Project .
    2 Wiper Motor
    1 Moto Monster Shield ( Change 1 per motor soon)
    1 Arduino Uno R3
    3 Monitor
    Logitech G27
    Running Simtools with RacingMat code
    Any suggestion would be great .. Thanks
    20160616_162552.jpg 20160616_162559.jpg 20160616_162607.jpg 20160616_162611.jpg 20160616_163607.jpg 20160616_163614.jpg
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    What do you use as universal joint ? It seems a little bit light..
  3. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Looking good. What are the extra square tubes behind the seat
  4. toanhung
    toanhung New Member
    - 16Coins
    It actually a ball joint for the lower front lower suspension from a car .
    Those extra where original chair was. but i move toward the front so i can have some angle for shoulder mount. was at bottom seat but i changed
  5. PiaMan
    607Coins
    Ahh. i placed a bunch of those in front of my chair for accessory mounts such as shifter and dash board, and one at the front pivot point for VR tracking camera but i couldn't figure out what they would be for behind the seat :)
  6. SeatTime
    Ball joint? Is it able to twist? Hope not.
    153,764Coins
    +11,149 / 57 / -2
    It has a panhard style bar so I am guessing it does.
  8. toanhung
    toanhung New Member
    - 16Coins
    Yes it does twist, I put a bar so prevented, but might change to u joint , if something doesn't work right .
  9. toanhung
    toanhung New Member
    - 16Coins
    So far moving slowly but sure do move.
  10. toanhung
    toanhung New Member
    - 16Coins
    More progress today , still more to do.
    20160630_174631.jpg 20160630_174638.jpg 20160630_174656.jpg 20160630_174705.jpg
  11. toanhung
    toanhung New Member
    - 16Coins
    Is there any easy solution for adjustable steering wheel height ? thanks
    Currently pedal are sitting on slider. but now i need to make for steering too ..
    153,764Coins
    +11,149 / 57 / -2
  13. PiaMan
    607Coins
    if you have two sizes of square tubing i just drill a hole and weld a nut onto the bigger size then the smaller size slides through and locks down with the bolt through the welded nut.
    1.25" and 1" works well as does 1.25" and 1.5"
    if it doesn't make sense i can take some closer pictures of my rig to show you
  14. toanhung
    toanhung New Member
    - 16Coins
    Thanks @noorbeast and @PiaMan , gotta find tube that are .25 bigger, local hardware store dont store that kinda size only .50 bigger.
    Still messing and getting used to the simtools lol.
  15. PiaMan
    607Coins
    see if you can find an industrial steel supplier. I found the cost is almost half what my hardware stores sell for and they are happy to do my little orders and even cut it into manageable sizes for me. In my case most of the time the lengths comes in 24' so its a lot but since the cost is so much less i just get to build more projects for the same cost
  16. toanhung
    toanhung New Member
    - 16Coins
    gotta find steel supplier. hardware store cost arm and leg lol. and only come with 3' outstock on 6'
  17. toanhung
    toanhung New Member
    - 16Coins
    On adruino can we define a finer motion? for example
    if (gap>50) pwm=215
    can i define more value between would that help on motion or that the only 3 speed it would go ? thanks
  18. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  19. toanhung
    toanhung New Member
    - 16Coins
    Thanks @insanegr , that exactly what i need.
