Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Awesome job dude, this looks so good. How much does your rig weigh? Where did you get the spring props from?
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    top part without rider is about 140 lbs not including arms and levers. i weigh around 160lbs. thats around 300lbs loaded, the springs reduce the load by about 180lbs total. i am using three 60lbs. i updated my parts list to include the springs in post #3 they came from ebay about 10 dollars each. i got the 10mm ball studs to mount them from summit racing for 1 dollar each.
  3. Historiker
    9,208Coins
    Jealous <-----(me)
    Great job!:thumbs
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
  5. SilentChill
    20,595Coins
    Nice job. I'm well impressed your motors that they are holding out with all that weight and not getting hot :)
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    @SilentChill they were getting hot after only 30 minutes before I added the gas springs. I sat in it and played off and on for over two hours last night with only a couple errors and 1 break (rod came loose). The monsters were running 125f before and last night after a run the hottest was 98f. The springs help a lot.
  7. SeatTime
    Excellent :thumbs another working DC motor 6DOF - it was not too long ago that we were told by certain experts that it was not even possible :p.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    Glad no one told me. I might have believed them. Ty to the guys who got it done before me and didn't listen to the experts. The inspiration and confidence was drawn from all your hard work.
  9. Nick Moxley
    Have you tested with something that isn't Dirt Rally ? Cant say ive been terribly impressed with the overall telem that is output.
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    @Nick Moxley I totally agree I'm not a huge fan of any of the code masters titles. They have an arcade feel to them. I have been running raceroom, and AC but one has no traction loss and on the other one it's broken. so the purpose of using DR was to show TL. I had 0 gain and 3 return in the vid.
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    for you nick:D yeah im still slow thats why the video is so short
    p.s. hey @Historiker, notice the shoes. :cheers
    • Like Like x 5
  12. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thats it, I am bringing my sim home and fitting it in my room somehow ;)
  13. SeatTime
    Its looking good, but I like to have more movement/feel more force - in simulating a racecar - it's why I built a 6DOF:D. Each to his own I guess.
  14. Historiker
    9,208Coins
    Oh my god?!?! Did I really see you turning left AND RIGHT?!!! :p:p:p
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes I like your profile much better. You have a much more range. I see where I need to adjust some tho ty for the example.
  16. SeatTime
    Yea, we are pretty out of control in OZ.
    • Funny Funny x 2
  17. Historiker
    9,208Coins
    @SeatTime, not you....the joke was directed at Bruce but your message and mine crossed in the void :)
    @bruce stephen considering your driving habits I had considered only sending you the right shoe :grin
    • Funny Funny x 2
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    I use both feet lol. Even if it's just to go left.
  19. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    have you calculated the load if necessary use gas springs with these motors? The motor power I orders is similar with yours. My platform and pilot is about 120KG. I didn't order gas spring.
  20. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Hi, how do you consider the rod ends position? which determine the center of gravity.
    From the car structural drawing, looks it should be position 1/2 and 4/5 (F1 maybe higher).
