News Alternative Plugin for DCS World
Discussion in 'Digital Combat Simulators (DCS)' started by RiftFlyer, May 30, 2016.
  1. noorbeast
    153,716Coins
    Then in my view you have it spot on, sorry I can't test as my sim is setup for beta testing.
  2. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    That's no problem @noorbeast. It seems a lot of the more active members have moved on to SimTools 2.0 Beta.
    @Adrianstealth is the only person to have graciously provide feedback so far. Guys if any of you have tested then please let me know how it works. My own setup isn't ready to test this yet so I'm depending on you for feedback.
  3. boosted-lt1
    boosted-lt1 Member
    Michigan, USA
    748Coins
    2DOF, JRK
    @RiftFlyer, I'd like to test both of your plugins. It may not be for a little while as I've been away for a number of months and need to sort out some functional issues with my rig which has been sitting around.
    So if I understand correctly the initial plugin which is linked to your first post uses roll rate not roll position. As you accelerate around the X-axis in a right roll the platform rolls right correspondingly to how hard the roll was/is initiated. Stop the roll in some position, say aircraft banked right 45 degrees, and the platform will level back to horizontal. @noorbeast I know really liked this setup in other sims.
    For the second plugin, please see image below and let me know if this is how you've got it set up. You removed the link for this one correct? Could you email it to me if I PM you my email contact? Thanks!
  4. RiftFlyer
    1,711Coins
    DC motor
    @boosted-lt1 the descriptions you've given for both versions are correct. I'll post the second version again when I get a chance. Adrian was to test it but I haven't heard back from him. I should find some time over the next few days to dig out the laptop and attach the second plugin here.
  5. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    sorry I'm hoping to get back into sim mode this week,
    I've been testing a new gtx 1080 & a solid state drive as well as adding a quick release to my flight stick etc
    will post back here as soon as tested
  6. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    ps those pics above from boosted explain well how it should work
    looking forward to test ping it
  7. Intruder
    Intruder Member
    435Coins
    Nothing new on this i think?!
  8. RiftFlyer
    1,711Coins
    DC motor
    Sorry been busy on other projects and had not received any feedback here. I've replied to the threads on dcs forums and can integrate mrsparks code for the alternative roll output if he agrees.
  9. Intruder
    Intruder Member
    435Coins
    Thank you! That would be fantastic!
  10. RiftFlyer
    1,711Coins
    DC motor
    No problem. Just waiting on his reply.
  11. Alex36
    Alex36 New Member
    rus
    279Coins
    Hi!
    Thanks for the plugin!
    I wanted to run the game with the plugin in table model 2DOF on the basis of RC servos.
    But servos do not work.
    In LFS work without problems.
    Tell me, please, what's the problem?
  12. Alex36
    Alex36 New Member
    rus
    279Coins
    How to change the DOF on AXIS output?
  13. noorbeast
    153,716Coins
  14. Alex36
    Alex36 New Member
    rus
    279Coins
  15. Alex36
    Alex36 New Member
    rus
    279Coins
    RC servos only move when you move the sliders "Axis1", "Axis2".
    When you start the game "Axis output" changed to "DOF output".
    RC servos do not work :(
  16. Alex36
    Alex36 New Member
    rus
    279Coins
    Файл конфигурации
    153,716Coins
    Have you patched to the game install folder?
  18. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    maybe you need setup first in tuning centre axis when you not setup in tuning centre (in game afte not work)
  19. Alex36
    Alex36 New Member
    rus
    279Coins
    Да, конечно, вот: Yes, of course, here:
  20. Alex36
    Alex36 New Member
    rus
    279Coins
    Tried it, when the game starts, immediately switch to the "DOF output"
