Did I Fry my JRK?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by pittperson, Jun 25, 2016.
  1. pittperson
    pittperson Member
    North Carolina
    550Coins
    Just when I thought I was ready to move my first motor, I had a very anticlimactic moment. I'm wondering if my horrible soldering skills may have fried my JRK.
    I have power at the PSU, Power at the JRK but nothing going to the motor itself.
    Any ideas?
  2. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    There won't be any voltage on the motor terminals unless the motor is being driven at the time.
    Are you trying to measure voltage while controlling the motor via SimTools or while in game?
  3. pittperson
    pittperson Member
    North Carolina
    550Coins
    No, not via SimTools or while in a game. I was just trying to use the Pololu Jrk config utility.
  4. SeatTime
    Your going to have to give us more information then that if you are really after helpo_O. Eg is there a feedback pot fitted?
  5. pittperson
    pittperson Member
    North Carolina
    550Coins
    Sorry. I thought I was doing pretty good with the info. I do not have a feedback POT fitted yet. I have the most simple setup possible right now. PSU -> JRK -> motor. The JRK is plugged into my computer and I'm running the Pololu utility. I'm assuming the "Run Motor" button would actually run the motor if everything were configured correctly.
    153,758Coins
    Part of the configuration is setting the min and max calibration for the lever, via the pot feedback, so the JRK knows what range to run the motor within.
  7. pittperson
    pittperson Member
    North Carolina
    550Coins
    Ok. I got my POT attached to the JRK and I get feedback in the variables vs time graph. So that looks all good. Next, I ran through the Setting Up Your System section of the JRK user guide, set the appropriate errors to Enabled and Latched, applied the settings and powered it up. Still no luck, the JRK LED is still red. Next, I ran through each error that should be set to enabled and latched individually and the only error that continues to stop the motor is the No power error. Its looking more and more like a bad JRK... in my noobie opinion.
  8. pittperson
    pittperson Member
    North Carolina
    550Coins
    Problem solved. Went back and re-soldered everything! Thanks!
  9. SeatTime
    I'm not trying to be rude, but this is all you originally told us 'I have power at the PSU, Power at the JRK but nothing going to the motor itself. Any ideas' and three pictures showing what you had just stated. I don't know your background, but that was never going to help us isolate your issue. Note that a JRK normally monitors the feedback line and will shut down the output if it does not see the right voltage. Glad to see you got it sorted.
