2 dof seat mover with cv
Discussion in 'DIY Motion Simulator Projects' started by Raredog, May 31, 2016.
  1. Raredog
    Raredog Active Member
    Denmark
    25Coins
    2DOF, JRK
    Not yet, but the rod ends and the pots have finally arrived :)
    Still missing some things, among others, 1 jrk...
  2. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    i went with the standard mount. But i really like your design
  3. Raredog
    Denmark
    25Coins
    2DOF, JRK
    That might end up beeing smart, we'll see :)
  4. Raredog
    Denmark
    25Coins
    2DOF, JRK
    The levers are done, and so are the rods :)
  5. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Aah, just thought about the angle on the levers... Is it better that the angle is 90 degrees?
    151,479Coins
    +11,041 / 56 / -2
    Maximum effective torque is when the lever is 90 degrees relative to the rod.
  7. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Thanks, I'll have to shorten the rods a bit then, I don't know why I thought they should be level with the ground...
  8. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Have anyone tried to make mechanical stops to prevent the motors from spinning around and damaging the pots?
    Would I risk frying something? I will of course make a safety switch.
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    do the jrk's have a limit you can set like smc3 max limit?. if so just use that.
  10. Raredog
    Denmark
    25Coins
    2DOF, JRK
    I have no idea, as i haven´t tinkered with the jrk yet :) I just thought that it might be a good idea...? If the pot fails or something, an electronic limit wouldn't help i guess?
  11. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    Hi @Raredog , nice to see someone else from DK here :) Good luck with your built, you'll enjoy, for sure.
    I have a hard time finding steel tubes here in our country, may I ask where do you buy them?
  12. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Hi
    I thought i was the only Dane here :)
    I bought the steel tubing at vvvs-eksperten.dk its ok prices, but it can take a few days, but its okay :)
  13. Vef445
    Denmark
    597Coins
    Actually I'm not Dane but yeah, living in Kolding :)
    Thanks for the address, I'll go take a look for future projects :)
  14. Raredog
    Denmark
    25Coins
    2DOF, JRK
    We are practically neighbors then, I'm living in Jels, 30 kms from Kolding :)
    ___
    I've decided to cover most of the sim in mdf.
    Behind the glass I will make a box for the electronics
  15. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Nearly finished with the box, the last jrk arrived to day.
    Also made a "dashboard" of a kind, but might have to make some vents for the wheel...
    Where can I find some sort of rough setting for setting up the jrk's?
  16. noorbeast
    151,479Coins
    +11,041 / 56 / -2
  17. Nick Moxley
    17,056Coins
    Fans and Heat sinks are 100% Mandatory. NO questions asked. Despite what Pololu may claim.
  18. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Thank you very much :)
    I have just added the heatsinks, the fan are still on the way from China, but I'll just use a temporary one while testing.
  19. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Got the left motor set up, but can't get the right one to work? If I measure on the jrk, it seems as no voltage is passing thru?
    JRK utility says: "error detecting motor direction"
    Error 1x0001
    What to do?
  20. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Found out; bad soldering on the motor.
    Both works now :)
    Now I just need to figure out simtools...
