how to choose DC Motor and Gear box?
Discussion in 'Motor actuators and drivers' started by DSSxSIM, Jun 29, 2016.
  1. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    I'm trying to build my own 2DOF seat,
    I'm kinda confuse about motors.
    this is what's in my mind:
    Wipe Motors is a cheaper way to get the motor and I guess the power may be much weak compare to DC motors.
    DC motors with gear box go much expensive and it should be much powerful.
    cuz the sellers around Taiwan net store never give clear spec info of their motors,
    I should find some 12V 3200RPM 30Wolt DC motors and two Worm gear box goes right and left, right?
    another problem is, I found there are different kinds of motor, like Server motor, Stepper motor, motor with brake. which one should I take??
    153,703Coins
  3. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    thank you,
    seems I should take 120 wolt or more.
    cuz Taiwan and China are no good relation on political.
    China take more tax duty for export to Taiwan after Presidential election.
    I'm looking around Taiwan factories.
    any other problem I got is it very rare to find worm gear box in Taiwan.
    and whats the scale should I take? 1:60?
    153,703Coins
    What you specifically choose for motors and gear ratios depends on the actual design you intend building. If it is a 2DOF shoulder mount seat shaker design then the 200 or 250W 25:1 motors should work well. If it were a compact design needing more torque then you may consider the 50:1 gearbox instead.
  5. toanhung
    toanhung New Member
    - 16Coins
    what you recommend for 3 dof ? for using with heavy
    153,703Coins
    It still depends a bit on design, there are some different ways to go about adding heave: https://www.xsimulator.net/community/faq/ways-to-add-heave.224/
    For a traditional 3 motor triangulated design you do need plenty of torque for heave, even with a spring to assist to help in carrying the load. So at least 12V 200W with either 50 or 60:1 gearboxes.
  7. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    the commercial seat I bought was built by 350w motors,
    it kills the monster motor after 2 or 3 hours racing.
    is that possible to make a fuse on it?
    153,703Coins
  9. DSSxSIM
    DSSxSIM Member
    Taiwan
    151Coins
    sorry, thats two deals.
    I own a commercial seat, but it got some problem like motor monsters dead, pots dead, and some how.
    it came from China, I have to repair it on my own.
    thats why I wanna to make a better one by myself.
    153,703Coins
  11. acadburn
    acadburn New Member
    North Dakota
    190Coins
    Might be a heat issue and not a fuse issue bud.
  12. todd
    todd New Member
    idaho
    309Coins
    Noorbeast...you seem to have some knowledge of this stuff. I am building a sim very similar to the one fly-Moscow is on the commercial forum, and I need to find out the motor gearbox info as well as rpm and torque specs required...know one seems to answer me. Do you have info or can you send me to someone who may....thx
  13. Jules de Ponte
    Jules de Ponte New Member
    South Africa
    178Coins
    In terms of torque, as a rule of thumb, how much is enough. I'm looking at some SEW Eurodrive motors with 40Nm.
    153,703Coins
  15. Jules de Ponte
    South Africa
    178Coins
    Indeed, I have since looked a bit more into the physics and calculated what I need. Thanks for the link.
