New User Project
Discussion in 'DIY Motion Simulator Projects' started by Bruce, Jul 4, 2016.
  1. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    New User/New Project
    Hi I am a new user my name is Bruce, i have just purchased the electronics needed to start my project and now are in need of the motors any ideas on where to purchase in Australia?
    I have just purchased an Ardunio Neo and a VHN2SP30 Monster moto shield driver.
  2. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    Sorry forgot to add that i am building the Sim from scratch so any format i can make work i am looking at the 2DOF would this do as a starter project?
    153,920Coins
    +11,156 / 57 / -2
  4. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    That is awesome Thank You
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Looking forward to seeing your build take shape.
    Ask questions, LOTS of questions :)
    More Aussie members into the fold!
  6. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    OK Guys need some help, I have built a test rig, all works fine when sending commands through the Arduino software. I am trying to get the iracing to work in Sim tools. I think i have everything correct but i get no response when in iracing???
    I have the game patched and it says connected. I have set up the interface 1 settings to com 3 the same as my Arduino and all other settings. What am i missing?????
  7. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    These are my settings?
  8. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    I have set the IP to my PC's Ip address of 192.168.1.105 i have checked the 4123 port and allowed it through my firewall.
  9. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    Update in output testing everything works fine, when i go to Virtual Axis and drive in Iracing there is no movement of the sliders so no game data is coming thorough??
    153,920Coins
    +11,156 / 57 / -2
    Can you explain what exactly your test rig consists of and what code you are running on the Arduino.
  11. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    The test rig is just using 2 wiper motors, and the code is from Racingmat 2DOF code
  12. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    Everyhting is working fine in test mode direction and travel is fine, just getting no data from Iracing plugin
  13. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    I am just testing with cheap motors at this stage to see if i can get it working before making the real rig and spending money on the proper motors
    153,920Coins
    +11,156 / 57 / -2
  15. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    I patched it using the sim tools plugin updater?? is that not correct maybe that is the problem as i did not know the patch path for iracing
    I have tried many axis assignments.
    It is green and says connected
  16. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    I asked ages ago about how to patch iracing and what the default path was but i had no reply. There is nothing in game patching path on the game manager
  17. SeatTime
    Have you looked at the FAQ?
  18. noorbeast
    153,920Coins
    +11,156 / 57 / -2
  19. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    All sorted, you are exactly right. The game was not patched correctly. All working fine thanks for your help...
  20. Bruce
    Bruce CM Security
    Security Tech
    townsville
    718Coins
    Hi Noorbeast, I done some more testing today with my mock up rig. I am going to order some new worm drive motors from the company you posted above. One thing i am worried about is the 200watt 20NM torque states that it has low holding torque. I am worried only using 2 motors that when some one sits in the seat the motor will rotate and the seat will fall?? Do i need something with holding torque when not powered??
    I am guessing as you stated that 50:1 and 60:1 options were also there but i could not see these on the site.
    These test motors i used do exactly the same thing you can rotate them with your hands. But like i said these were just for testing purposes.
