Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    If that's the French saccade, then it means twitch, jolt. ;)
  2. zigzag49
    zigzag49 Active Member
    723Coins
    :thumbs
    In other words, roll does not work even with the latest update .
  3. mohammad
    mohammad Member
    iran
    159Coins
    hi @kermitkong
    I use frontier.
  4. mohammad
    mohammad Member
    iran
    159Coins
  5. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,238Coins
    Hi @mohammad , Hi @SilentChill ,
    I can confirm that ROLL has some unexpected behavior. ROLL stucks again. Few times I didn't have problems, but now ROLL doesn't work properly again. I think the pointer for ROLL maybe wrong.
    I've some time tonight to test more. Maybe There's an update available for a deeper test for tonight.
  6. SilentChill
    20,591Coins
    So everything works okay apart from roll ???
  7. kermitkong
    1,238Coins
    after a quick double check last night, i can say that only ROLL has this issue.
  8. SilentChill
    20,591Coins
  9. kermitkong
    1,238Coins
  10. mohammad
    mohammad Member
    iran
    159Coins
  11. SilentChill
    20,591Coins
    Does it @kermitkong work I have tested here for 2 hours with no issues hopefully its ok for everyone else
  12. mohammad
    mohammad Member
    iran
    159Coins
    hi @SilentChill
    how linke download?
    I download linke DOWNLOADNOW in up page
    but old plugin download
  13. SilentChill
    20,591Coins
    @mohammad the download is the new plugin I have updated it, does it still not work ???
    Inside the zip file EliteDangerous64_GamePlugin.dll modified time of 19:30 today ???
  14. mohammad
    mohammad Member
    iran
    159Coins
    @SilentChill I download linke DOWNLOAD NOW in the up
    in the zip file EliteDangerous64_GamePlugin.dll 7/2/2016 6:44
  15. mohammad
    mohammad Member
    iran
    159Coins
    @SilentChill why the my plugin download modified time Difference
    I Thought plagin I downloaded is old
    why new plugin no download ?
  16. SilentChill
    20,591Coins
    Arghhh you are right @mohammad I just downloaded it here at work it has not got the updated plugin ??? I have no idea what I have done, or not done. I will upload it again as soon as I get home
  17. SilentChill
    20,591Coins
  18. SilentChill
    20,591Coins
  19. SilentChill
    20,591Coins
  20. SilentChill
    20,591Coins
    For some reason its not updating the plugin in resources ???? I have posted it here instead, see if this works
    @RaceRay you any idea why ?
    edit: This is the updated plugin I have no idea whats going on with the resource version ???
Thread Status:
