my new simulator 3dof with 3 ac motors even in beta. building
Discussion in 'DIY Motion Simulator Projects' started by juan_l, Jul 8, 2016.
  1. juan_l
    juan_l Juan Luis Durussel 3dof
    Ingeniero
    argentina
    - 369Coins
    3DOF, AC motor
    It is mounted on a universal joint
    motion cam gear motors
    BOARD OWN
    ONE FOR EACH MOTOR TO INCREASE EFFICIENCY
    ADJUSTABLE FOR DIFFERENT SIZES
    END OF PIPE WITH MOVEMENT
    G27 PEDALS IN 3D
    152,445Coins
    +11,078 / 56 / -2
    Does the universal move up and down to allow heave?
  3. juan_l
    Ingeniero
    argentina
    - 369Coins
    3DOF, AC motor
    SEAT SPARCO IN 3D
    Does the universal move up and down to allow heave?noorbeast
    G27 SHIFTER 3D
    G27 WHEEL 3D
    REDUCTOR STM UMI 40 FA
    TOP FRAME
  4. Historiker
    9,208Coins
    Please do not post one detail per post. It clutters up the thread and makes it appear as if you were spamming for coins.
    I edited your posts for you to clean them up.
    Nice build, and thanks for sharing the files. I look forward to your finished project.
  5. juan_l
    Ingeniero
    argentina
    - 369Coins
    3DOF, AC motor
  6. Nick Moxley
    I dont get it either. Looking at SEAT IDZ 4 pic, you can see something there, But im lacking to understand how that will work exactly. :confused:
    Any more details for us @juan_l ?
  7. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    With that kind of motors I don't see the need of a heave assist.
  8. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    From what I am seeing (I have a 3dof AC Platform) - He will have heave.................he looks to have a square tube that will move up and down - and is surrounded with roller bearing for tube stability and
    ease of movement....................on top of this tube, he has the u-joint attached..............IMHO, it will work.
    Tom
    PS - I use a 7 tooth Spline Shaft and Shaft Collar - Mine has spring assist.
  9. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sure it will work, I just don't see the need of any kind of assist or central guide.
  10. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    As "Close" as his three motors are together, a U-joint/Central guide is not necessary, "assuming his motors/gearheads are correctly matched and heavy-duty enough............
    IF his motors "were" spaced further apart (like mine are) then a U-joint/Spline Shaft / and in some cases, a support spring are necessary................all depends on the total weight
    of the of the top platform including rider.
  11. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sorry @cthiggin , we are talking about his design, please don't take it bad. Also we are just assuming for the looks because there isn't any description, just looks like he is using powerful ac motors in a super compact design. I hope my fellow countryman gives us more info soon.
  12. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    mariano68,
    No problem........
    Blessings
