Tutorial How to convert your Frex SCM to SimTools - Updated
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MasterYoda, Feb 21, 2009.
  1. Mif
    Mif Member Gold Contributor
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Yeah, you may need to reverse or play with some of the settings based on your specific sim. Glad its working for you!
  2. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    Thank you very much, Mif, you have been a great help! I definitely would not have figured it out by myself. Have a great day and thanks again. :cheers
  3. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    By the way, what is the easiest way to reverse an Axis? Do I use the Game Engine or the Tuning Center? Thanks.
    • Disagree Disagree x 1
  4. Historiker
    9,207Coins
    You use the boxes next to the axis in the game engine. You will have to shut down the game to do so though.
    150,043Coins
    +10,993 / 54 / -2
    You can fix pitch reversal in the SimTools Axis settings using the Dir check boxes in Axis Assignment tab. Checking or uncheching them reverses direction, depending on which way you currently have them.
  6. RayRay
    RayRay Member
    Toronto
    559Coins
    SCN5
    You guys are awesome thank you very much! This is such a responsive community. Hope I am knowledgeable enough someday to help someone else too.
  7. damar
    damar New Member
    hongkong
    202Coins
    very helpful. Thank!
  8. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    i shall be having a good read of this topic over the weekend once i'm set up. thanks
  9. Sento Siete
    Sento Siete Member Gold Contributor
    Valencia (Spain)
    304Coins
    2DOF, SCN5
  10. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Just fixed the figures that were still attached, but missing in the middle of the text... Hope it's clearer now.
  11. liulong821170
    liulong821170 Think about the speed of the wind.
    Engineer
    NO.49 shixing Road,GuangZhou,GuangDong,China
    248Coins
    2DOF, SCN5, Motion platform, 6DOF
    If my SCN5 is 50mm that should be how to set it?
  12. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    Hi Guys,
    New user here :)
    I have followed the step by step instructions and i can move the actuators manually with my mouse using the axis testing sliders but i don't get any game data. Ive read through the forum, tried several options and settings but still no luck.
    I need your help ;)
    Thanks,
    Robert
  13. noorbeast
    150,043Coins
    +10,993 / 54 / -2
    I see you have posted the same question on the welcome thread.
    It would help if you start your own project thread here and detail what you have done so far, including pictures of all settings, as it could well be a configuration issue: https://www.xsimulator.net/community/forums/commercial-simulators-and-peripherie.52/
    What game are you trying to use, is it patched for motion and if so to what path?
    The SimTools documentation is here: http://www.xsimulator.net/simtools-complete-documentation/
    And here are the steps to creating motions profiles: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  14. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Question(s) related to a converted Frex..
    Does anyone know if I can use a 240v power supply thats connected to my Frex in the USA..? Should I put a converter between it or do I have to buy a new power supply..?
  15. Jewly
    Jewly New Member
    Korea, Republic
    222Coins
    Oh.. Thank you
  16. bergstein
    bergstein New Member
    CHINA
    224Coins
    Thanks for sharing
  17. Mif
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Use the diagram on the first post. I have included it again here for reference. SCN5_X-Sim2_Diagram.JPG
  18. Mif
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    I do not understand unfortunately. Can you take a photo of your connections? I may be able to help.
  19. Mif
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    You should not have to modify the connector, use the other end that would usually go to the Simcon Motion box. You have to cut the wire, then strip and connect to the rs485 connector using the diagram. the Molex connector will still connect to the SCN5. Your colors may be different, just make sure it matches. I had a photo but I deleted it from my phone and my connector is buried inside my simulator.
  20. Mif
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Oh! I see now. I missed the part about ATX 4 Pin. You can do that, just make sure it matches to the diagram. I cut my wires, as the simtools is WAY better. I think you would be fine to cut it, you can always reconnect it with solder or crimp no problem, but I bet you will never go back. Simtools has better support, better motion profiles, and is more up to date. I will never go back.
