Solution Race07 and pCars don't work (or work but few)
Discussion in 'Game Engine axes presets' started by Sento Siete, Jul 10, 2016.
  1. Sento Siete
    Sento Siete Member Gold Contributor
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    Hi, I had a problem with Race07 an pCars plugins: The seat moves but just milimeters.
    I've solutioned it coping the content of the MaxMinProfile of other game that works (in my case Assetto Corsa) to the Race07 and pCars files, and deleting the original content of this files, obviously.
    153,758Coins
  3. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    Yes, and I'll modify it but until I learn enaugh to do it, I can play with those games.
    It's just a quick and easy solution in the meanwhile :)
  4. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    A super quick way to setup profiles, if you are impatient or just want to test a plugin....
    In GAME MANAGER, set your MAIN profile down to 10%
    (Click Profile manager, set MAIN LEVEL to 10%)
    Fire up your game of choice...
    Then open up TUNING CENTRE (Right click GAME ENGINE)
    UNTICK all the MAX/MIN Balance boxes.
    CLICK on CAPTURE MAX MIN and then hit RESET to put all the values to ZERO.
    CLICK "Save New Settings", then STOP the CAPTURE.
    Once in the game, RESTART the CAPTURE and go for a drive, mount the kerb a few times, brake hard, accelerate, sway from side to side...
    Click SAVE NEW SETTINGS again and then STOP the CAPTURE. (Click SAVE before the STOP... this always catches me out!!)
    This will give you the MAX and MIN of each force / axis as a good starting point and you can tune them from here.
    Only use this method if you have already set the direction of your AXIS as it will not feel right otherwise.
    IMPORTANT: Ensure MAIN LEVEL is 10% or LOWER, or you will shake your SIM to pieces when the MAX MIN level on Tuning is at Zero.
  5. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    Thanks!!, I'll try it next weekend
  6. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
