Project : Sim racing
Discussion in 'DIY Motion Simulator Projects' started by Benjamin oh, Feb 20, 2016.
  1. Benjamin oh
    Benjamin oh Member Gold Contributor
    234Coins
    DC motor
  2. Benjamin oh
    234Coins
    DC motor
    What I am trying to achieve :
    3 Dof Simulator hopefully Similar to Simxperience stage 4 .
    (I am not looking for extreme movement, just looking for quick and precise/ small movement feedback for Iracing & AC .)
    Problem I am facing :
    1. Gearbox with a lot of free play
    Solution : Use Shims (Read it from Nick Moxley thread)
    2. Change of potential meter and Change the location of potential meter
    Solution : not known yet
    3. Reduce the seat height of the current seat mover
    4. Change position of the Motor
    Solution : not know yet
    5. Add the 3rd DOF
    It will be great if anyone can help and advice me =)
    153,788Coins
    +11,150 / 57 / -2
    Here is some existing traction loss information: http://www.xsimulator.net/community/faq/traction-loss.174/
    As traction loss involves a top and bottom frame you may want to consider cannibalizing your existing compact simulator for parts and converting it into a shoulder mount frame design.
    You could use Hall sensors instead of pots and mount them directly to the motor shaft with a flexible coupling: http://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
    Have a slight amount of forward weight pre-load on the motors and replace the rose joints with tie rod ends should help with the play, though there will always be some with wormdrive gearboxes.
  4. Benjamin oh
    234Coins
    DC motor
    Hi noorbeast , thank you for your prompt reply.
    I will read up on it tonight
    I am planning to convert it to a shoulder mount frame design.
    For sure I have to cannibalising and make use of everything thing I have currently
  5. Nick Moxley
    Oh man i had No idea the rabbit hole i was jumping down when i started to build this, Lol
    Im glad my build has partially inspired you to build your Own ben. Any specific question's dont hesitate to ask.
  6. Benjamin oh
    234Coins
    DC motor
    @Nick Moxley your project sure did...
    Looks like I will need a lot of time for this project.
  7. Benjamin oh
    234Coins
    DC motor
    Progress as of (20th July 2016) :
    Computer Aided Design :
    Using Profile Aluminum (4040)
    Please note that the design of the rear section is not complete.
    Profile Aluminum Accessories (15 July 2016):
    Treading of Profile Aluminum End (16 July 2015) :
    Cleaning of Hobby Room(18th July 2016) :
    The Start of Motion Platform Building (19th July 2016) :
    The build continues!
  8. Benjamin oh
    234Coins
    DC motor
    Progress as of (21th July 2016) :
    Shortening of some 4040 Profile Aluminium :
    Assembly and Levelling of Steering Wheel Platform :
    Racing Chassis Progress :
    What is next :
    1. Waiting for more accessories to arrive from China ( Swivel Plate and etc)
    2. Computer Aided Design for Seat Mover Platform
    3. Upgrading of Motion Simulator Components
    4. Wood Base
    • Like Like x 5
  9. piorck
    piorck Member
    french
    258Coins
    very nice you're picture
  10. Benjamin oh
    234Coins
    DC motor
  11. Benjamin oh
    234Coins
    DC motor
    Hello Guys
    I am in the midst of building a base platform.
    By any chance could you guys share with me how many degrees of yaw do you usually have on 3 Dof Traction loss simulator ?
    153,788Coins
    +11,150 / 57 / -2
  13. Benjamin oh
    234Coins
    DC motor
  14. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    I have 420mm of movement at the back wheels, I haven't converted that in to degrees. I think I could go up to around 500mm but 420mm already is tons. As Noorbeast said, most rigs are 200-300mm
  15. Benjamin oh
    234Coins
    DC motor
    @avenga Nice rig you have there...
    Your changeable length lever is really cool. I will try do something similar to yours.
  16. Benjamin oh
    234Coins
    DC motor
    (26th July 2016) :
    15 Degrees Yaw angle mock up :
  17. Benjamin oh
    234Coins
    DC motor
    (29 July 2016) :
    Spend a day at my local Metal workshop
    Larger mounting plate , Shortening and Re-welding of U joint :
    Fabrication of Seat frame :
    Both item will be sent for powder coating =)
    Purchased a 12 inch swivel plate :
  18. Benjamin oh
    234Coins
    DC motor
    Hello Guys
    How do you guys secure your shafts to the worm gear box?
    Did you use the two grub screw slot? Will it be enough ?
    I am about to lathe a new shaft out.
    Thanks =)
  19. Benjamin oh
    234Coins
    DC motor
    31 July 2016 :
    Arrival of more accessories
    Rubber matt to dampen vibration :
    Mounting of swivel plate and further bracing :
  20. Benjamin oh
    234Coins
    DC motor
    Date : 03 Aug 15
    Angular Wheel plate with Vibration damping :
    360 Degree Hall Sensor :
    16mm Steel Rod ready to be Lathe :
    Progress as of 03 Aug 2016
