SimTools Presets 2DOF Arduino Simulator with rear wipers
Discussion in 'Game Engine axes presets' started by RacingMat, Nov 6, 2013.
  1. Historiker
    9,205Coins
    Yes, using an appropriate sketch it does very well. I am using one myself.
  2. RacingMat
    21,081Coins
  3. Historiker
    9,205Coins
    This is the one that I use King, there are several others, including RacingMat's that he linked you to. I have tried them all and each has slight differences but work well.
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    Thanks Mat, good to be able to play on the forums again. The house is done and I have some "free" time again :)
  4. RacingMat
    21,081Coins
  5. RacingMat
    21,081Coins
  6. RacingMat
    21,081Coins
    you cannot see the comport of your Arduino in GameEngine?
    is your arduino a clone or a true one? with arduino clones, I have experimented some trouble to establish a comport
    try to unplug and replug your arduino and to relaunch Game Engine
  7. SeatTime
    If its for your Uni assignment, aren't you suppose to be designing it ;)? Or does that not matter anymore:think. Irrespective, you have been given plenty of information - so I hope your not doing an engineering degree :rolleyes:. :grin
  8. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    Good on you @
    Good on you @SeatTime there are some people that don't want to, or are incapable of doing simple research, and expect to have everything handed to them on a plate!! JUST READ WHAT'S ON THE SITE, IT'S ALL HERE!!!!!!!!!!!!!!!!!! and then start asking questions.
  9. SeatTime
    Really? - Have a good life - out.
  10. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    hello guys.. so I have some question about the code because I already assembled the mechanical parts and test without program,
    now.. I want know if I get start with this code, I'm trying use "arduino uno + monster + PSU hp dps 600pb + 2 truck wiper..
    thanks in advance.
    153,703Coins
    This thread is about presets, so it would be best to post your unrelated questions either in your own build thread or the FAQ threads:
    Create your own build thread here: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    If you just want to ask a question use the search function, check the FAQ section and if you don't find an answer then create a thread here: http://www.xsimulator.net/community/forums/diy-motion-simulator-building-q-a-faq.31/
    The FAQs do have a dedicated section to the various Arduino codes that could be used: http://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    There is also a dedicated MM section in the FAQs: http://www.xsimulator.net/community/faq/motor-driver-for-arduino-compatible-controller.11/category
  12. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    thanks.. do you know where I can get alson the code to test my motors by controller/joystic?
  13. noorbeast
    153,703Coins
    Yes, the information is in the FAQ link I gave you, but as I said start your own thread, this is not the place for your unrelated questions.
  14. Narendra Singh
    Narendra Singh Member
    23Coins
    hi i'm new here and i'm building a 2dof car simulator first time i done every step by step but i'm not getting motion data from lfs to simtool i don't know what should i do now so need your support
  15. kingh3
    kingh3 Member
    256Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Motion platform
    I saw that error. You should reinstall LFS, and play some race before you add LFS to simtool. I have solved my error like that, and I hope it's useful to you. :v :) :cheers Good luck!
  16. Narendra Singh
    23Coins
    thanks dude but nothing happen i did this process
  17. Narendra Singh
    23Coins
  18. kingh3
    kingh3 Member
    256Coins
    there are some difference between the version of LFS. You should try with other version LFS. I don't remember excactly what version I used. You should try with LFS 3SP, LFS 3J6 and play racing (not play training) before add to simtool . . . Good luck. :):)
  19. kingh3
    kingh3 Member
    256Coins
    153,703Coins
    Troubleshooting for your rig has nothing to do with this particular preset thread, so best you start your own thread here and detail what you have done: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Please post pictures of all your settings, such as Axis Assignments and advise if you have patched LFS for motion with Game Manager and if so to what path, and do you get a success message for patching?
    Please state what code are you running on the Arduino and if you sim moves OK in Output Testing?
