  1. noorbeast
    153,710Coins
  2. Deleted member 22447
    @noorbeast
    Thank you for the quick response and suggestions. Du-ally noted!
  3. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    im having a hard time understanding i want to mode 1 but i do not no how to edit the code i have flashed to my uno3 and at the top it say mode 1 or 2 how do i edit to use 1
  4. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    In the line 9
    #define MODE1 or #define MODE2
  5. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Thanks for the help I have been running simtools on my pre bought rig for a little while now but I want to build my own and I'm a welder fabricater by trade and all stuff talking about code is over my head I posted pick were it says #define mode 1 does that mean I'm good I'm guessing if I wanted to run mode 2 I would change the 1 for a 2 every one is probably laughing there a--'- off at me
  6. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,441Coins
    @Justin Dail, correct just change the 1 to 2... Make sure you keep the formatting the same though, capitals for MODE and no space before the 1 or 2.
    So the line will end up being either (depending on mode selected):
  7. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Thanks I get now :)
  8. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Motors and other stuff should arrive this week for now I'm checking how it with 12v fan but I have a few questions for as set up output bit range /out put type binary decimal or hex and what to put for startup output
    Shutdown output
    Sorry for all the questions here's a pic of what I have so for 20160725_203834.jpg
    153,710Coins
  10. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Man y'all are the best such a thriving comunity thanks for the help such a abundance of info here mabey one day I will be able too contribute too
  11. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    @RufusDufus ...
    In SimTools startup and shutdown and with your firmware programed in the Arduino ...
    Is there a special command can be written Plus the target position to give a momentary slow motor PID response other than that PID stored in the Ard.
    That is so to have a slow up and down parking motor motion especially for 6DOF rigs ... Arduino can continue working with the normal stored PID in it in between that .
    Also Another question please ... what AB<255> means with @prilad F/W ?
    any readable material explaining that would be great ...
    Thanks buddy .
  12. RufusDufus
    Adelaide Australia
    16,441Coins
    Hi @speedy, no there is nothing really to do that at the moment. :(
    I can have a look, it may not be too difficult to add a command to slowly move to a specified location?
  13. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    For some reason I can't adjust the pwm max
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    You need to turn on the motor. Top left. This is a safety feature for the limit.
  15. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Yeah I noticed it after pic but even when it's switched to on position it still want show nothing for pwm I'm going to reinstall everything tonight also I'm not sure if I'm putting MODE1 in right place I put it at very top and hit upload to my uno could some one please post a pic of were they added code MODE1 or MODE2
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    For mode 1 change nothing add nothing this is the default setting and should be what you get "out of the box " so to speak. Try compiling and uploading smc3 with no changes.
  17. RufusDufus
    Adelaide Australia
    16,441Coins
    It is very unusual that some values can be changed and others can't. This maybe indicates a problem with communications - noisy signal. Does it do the same with each motor and if so is it the same values on each motor that can't be changed?
    If other motors are OK try using the copy buttons to copy the settings from a good motor to the bad one in case there is a corrupt value somewhere... although I thought I built such checks into software... can't remember now. :think
  18. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Ok that's good that helps alot ok I just tried it and I checked with 9volt battery and small motor I have pot coupled to motor and I can move slider up and down in manual and motor will turn but for some reason I still can't adjust pwm max I'm gonna read back through to make sure I haven't missed a step thanks for the help
  19. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Your software is great so far I've only tested 1 motor at a time I'm still trying to get the hang of things I appreciate everone help
  20. Pit
    30,510Coins
    Hi Justin, re-upload the sketch again, check all baud settings and test the Arduino first with the SMC3 utility later with one potentiometer only.
