12V DC Motor 6DOF Motion Sim Project
Discussion in 'DIY Motion Simulator Projects' started by Racing Mike, Apr 27, 2016.
  1. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    hug:thats exactly what I was looking for thanks
  2. Racing Mike
    Racing Mike Member
    Chile
    348Coins
  3. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Thanks for site theres a lot of options there I got to find some good mm's I received 6 and all were faulty I have 20 on the way so hopefully I'll get some that work
  4. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    Please post the place where you bought them so the rest of us can avoid them.
    @noorbeast maybe we can start a black list for MM sellers, looks like the MM issues continues.
    153,770Coins
    +11,149 / 57 / -2
    There are lots of liability related reasons not to have a black list on a public site, but we do have recommended suppliers list in the FAQs.
  6. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    How do you test the MM's ?
    153,770Coins
    +11,149 / 57 / -2
  8. SilentChill
    20,601Coins
    Or my way which is easy if you dont have a ocilopicalepetite
  9. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    I tested, about 6 MMs has output issue, some MMs A1 CAN'T reach 12 V(about 10-11V ), some A2, some B1 or B2. Is it matter?
    And which wire do you use? I use 12 AMG. Too thick to wired.
  10. SilentChill
    20,601Coins
    Deffinatley not too thick wire, remember we can be pumping up to 120amps through these things at peak . All it is is very poor cloned VNH2SP30 chips from china
  11. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    My motor is 300w, so I consider 15A for each VNH2SP30
  12. BlazinH
    16,689Coins
    I’m using 12v 600watt motors which at stall pull 135 amps. Using that for comparison, a 24v 300watt motor could pull up to 33amps when stalled.
  13. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Mine is 12V also. I use 2 chips for each motor to avoid heat issue and for redundancy.
  14. BlazinH
    16,689Coins
    Oh yeah, I forgot VNH2SP30 are 16v max.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
