Xilence Cooler for Moto Monster (Sparkfun)
Discussion in 'Electronic and hardware generally' started by Pit, Feb 1, 2015.
  1. Pit
    30,512Coins
    Found this effective and cheap "Xilence Cooler Northbridge Heatsink":
    If you use a Moto Monster and you have no idea what to buy or you do not have an old AMD cooler at home, this cooler will fit perfectly.
    Please beware: you do not need to cover the mosfests, only the vnh2sp30 chips!! To get the best fitting please cut the bottom plate as showed on the picture below:
    • Useful Useful x 3
  2. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    i build my controller box right now, and was thinking about the cooling. This info comes just at the right time :) They look perfect for my box.
    Thanks for the Post!
    Did you already use it and is the small fan enough? I see many people using 120mm Fans.
  3. Pit
    30,512Coins
    Next week I am going to build a complete new set of two MM's using this cooler, because today I found a shop in Switzerland which should have them in stock obviously. I am using a 120mm fan as well but the cooling is not so effective as I thought. Whatever this cooler is so cheap so it is worth a try in any case.
  4. BlazinH
    16,697Coins
    These appear to have about the same size fan (less than 50mm) that is supplied on the sabertooth 60x2. The sabertooth has a larger heat sink under the fan though to cover all the components needed for two motors. I use around 1hp motors on my sabertooths however they rarely get hot enough for the cooling fans to even turn on.
  5. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    recieved 2 of these today. They are fitting very good over the chips, But they are not very plan because my mosfets are a little bit higher. I hope the Thermel copunt can fix this gap.
    They are very easy to mount!
    Thanks again for the tip.
  6. Pit
    30,512Coins
    you do not need to cover the mosfets.
  7. Pit
    30,512Coins
    PS: In the meantime I got the coolers, too and cut the bottom plate, the cooler covers the vnh2sp30 chips completely.
  8. RacingMat
    21,087Coins
    • Useful Useful x 2
  9. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    Is it absolutely safe not to cool the MOSFETs?
  10. Pit
    30,512Coins
    The mine are running since years now... w/o cooling the mosfets.
  11. hoopstar
    hoopstar when 10/10ths isn't enough..
    Electronic Engineer
    Adelaide
    49Coins
    How are guys retaining the heatsink to the IC..??
  12. anatachaikiet
    anatachaikiet New Member
    184Coins
    hi. This one has 3 cable and how do we connect?
