MM die after I
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Justin Dail, Jul 27, 2016.
  1. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    This is my first time using arduin and mm I'm using smc3 to control as of now I've killed 2 mm just by turning the 10k pot I must be doing something wrong I did get one to read 11v on A1 to B1 but as soon as i twist pot the mm dirction light lights up and then mm dies any help would be geatly appreciated
    152,541Coins
    +11,085 / 56 / -2
    It is hard to say what you may have done wrong without pictures of all settings and wiring.
  3. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Ok here's a pic of how my 10k pot is wired +5v from ard and mm to pot I'll post some more pics after we determine this is right it's kinda of hard to see with all wired thanks for help
  4. Pit
    30,497Coins
    Hi, I don't think that the poti causes the issue. You didn't wire the control pins so the poti does nothing. There could be more reasons, first the MMs were DOA or the PSU is defective or the polarity was changed by accident.
  5. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    The other 2 mm I had them wired fully that quit
    I just wanted to show the pot wiring by itself then I will connect rest of wires befor I try it I will use another psu and snap another pic
  6. Pit
    30,497Coins
    ok, but honestly you cannot burn the MMs on the 5V line. So the issue is somewhere else.
  7. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    I gotcha i have 2 more mm's on hand and some more ordered will swap psu tonight and check them thanks for the help
  8. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    I swapped psu and mm are running the only problem now is trying to find some that are not faulty out of the 2 I tried are both out putting less than 12v
    The first one was 4v on both sides and the other was 5v I have more on the way today so maybe I'll have better luck with those thanks for the help
  9. Pit
    30,497Coins
    Obviously DOA. If you ordered from a serious vendor/dealer money is back guaranteed.
  10. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Question once you fin good ones what kind of life span have you been getting out them with keeping them cool I plan to use 2 dual boards per motor I know different set ups and settings will vary life span just curious tho cause this seems to be a good set up for as bang for your buck
  11. Pit
    30,497Coins
    My MMs are still working after more than 2 years of excessive driving. If they work (from the very first beginning) they will not fail (mostly lol).
  12. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    That's good to hear :)
