help dashboard
Discussion in 'Miscellaneous' started by Luciano merlino, Aug 1, 2016.
  1. Luciano merlino
    Luciano merlino New Member
    116Coins
    2DOF, JRK
  2. Luciano merlino
    116Coins
    2DOF, JRK
    how to set gamedash for project cars
    152,541Coins
    +11,085 / 56 / -2
  4. Luciano merlino
    116Coins
    2DOF, JRK
    thanks for your help but for me it is difficult because I must translate everything from English into Italian , I find the settings to be copied to poject cars with this type of dashboard , make a exception for a wimp like me hahaha
    152,541Coins
    +11,085 / 56 / -2
  6. Luciano merlino
    116Coins
    2DOF, JRK
    I use a nano v3 clone could this be the problem ? is recognized so ' ! The manufacturer's drivers are CH341 to load the code I used codebender 'cause the Arduino program does not work , it did not charge me the sketch
    or am I wrong in something?
    thanks for your patience
    152,541Coins
    +11,085 / 56 / -2
  8. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    see serial output settings in settings menu :
    COMxx - 115200 - 8 - N - 1
  9. Luciano merlino
    116Coins
    2DOF, JRK
  10. Luciano merlino
    116Coins
    2DOF, JRK
    in this video you can see that the code is loaded , I tried to set as you said but it seems that gamedash not communicate with the nano , just come home sedges more photos
  11. Luciano merlino
    116Coins
    2DOF, JRK
    noordbeast I tried to download the plugin you posted but it tells me that I do not have permission
  12. Luciano merlino
    116Coins
    2DOF, JRK
    here is my configuration I have to set something ?
  13. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    run program as "Adminisrator" ?
  14. Luciano merlino
    116Coins
    2DOF, JRK
  15. Nathan Older
    Nathan Older Member
    211Coins
    did you get this working in the end ?
  16. Luciano merlino
    116Coins
    2DOF, JRK
    No
  17. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Dal quel che ho capito, per utilizzare SimDash 2.0 devi acquistare la licenza del software.
    To use SimDash you must buy license of software.
