value1
Test Drive Unlimited 2 Plugin 1.34.16.2
SimTools game plugin for Test Drive Unlimited 2 (Boxed version and Steam Version)
  1. value1
    14,236Coins
    Test Drive Unlimited 2 Plugin - SimTools game plugin for Test Drive Unlimited 2 (Steam Version)
  2. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  3. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Ohhh this is good news !!! Finally one of my favorite ones :cheers
    Maybe its easy to do the first one "test drive unlimited" too ?? :thumbs
  4. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @value1 My happyness was only short.....its not working on my simulator, is that because I have the normal cd version of this game and not the steam one ?
  5. value1
    14,236Coins
    Most probably yes. Send me your CD and I can fix it ;)
  6. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @value1 hmm I could do that, send me your adres and I will do that, from Belgium to switzerland is not that far....
    Or maybe tell me how to do it myself :think
  7. value1
    14,236Coins
    @Al.Bundy
    Make sure you run GameManager in Admin mode! If this doesn't help try this:
    Download and install CheatEngine. During the installation do not accept the installation of additional crapware ;-)
    Connect CheatEngine to TDU2.
    In TDU2 enter the drive academy into the GPS
    Drive to the academy
    Enter 2 and 10 into CheatEngine:
    Drive along this road at a speed between 10 and 35 km/h direction south and press First Scan.
    Turn your car and drive backwards at a speed between 10 and 35 km/h in direction south. Press Next Scan.
    Stop the car and enter ExactValue 0 in CheatEngine. Press Next Scan
    Enter -10 and -2 into CheatEngine:
    Drive foreward at a speed between 10 and 35 km/h in direction north. Press Next Scan.
    There will be a few green addresses.
    Send me these or better a printscreen.
  8. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Thanks for all your efforts on this one @value1 - You already know how much I like this game!!! ;)
  9. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @value1 , let me start with thanking you for trying to help !
    The last 3 hours I have been busy to follow your guide....the real problem is that my mouse will not work when the game is playing in a window so that makes it extra hard to do, also after pushing first scan in cheat engine and then two times next scan there is no more working button to push the last time next scan...if you know what I mean ???
    Anyway I managed to get these two screens after doing my best....i really hope this is something you can work with.
    If not I can always send the CD to you ;)
  10. value1
    14,236Coins
    Hi @Al.Bundy
    You can switch out of the game window with <alt><tab> and then use the mouse as normal.
    When you run the car up to 50 km/h you can switch out and press the button, when the speed is between 10 and 30 km/h.
    The few green addresses should all show the same value.
    It appears to me that you have been looking for "4 Bytes" values instead of floats.
  11. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Ok ok, I will try again !!
  12. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    @value1 I tried again on float, but i just do not seem to get that last step.....then I saw that you use the cheatengine 6.3, while I am using the newer 6.4, so I downloaded 6.3 and tried again and again with no succes, it seems like the last step does not give me those green numbers you are looking for :( I guess I do not have the skills for programming ?
    So I chickened out !!! Grrrrr :oops: and took a nice enveloppe and put the cd in it and tomorrow will be send to you .
    I also put the game TDU unlimited ( the first one) in it so you could have a go with that one too if you have the mood for it hehehe.
    Too bad it is a long drive from belgium to switserland or else I could bring them and see and ofcourse testdrive your simulator ;).
    So thanks a lot for your help allready and the will to help me with my plugin problems maybe one day I can return it !! :cheers
    Your Friend Al.Bundy
  13. Historiker
    9,205Coins
    You are a saint, I loved playing this game until I built my motion platform. Without motion, games just....well....suffer.
    (No, the house is not finished yet but I really wanted to play games again so I set it up in the basement of the new house) :)
  14. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
  15. yjgogqqq
    yjgogqqq New Member
    河南省禹州市
    241Coins
    Test Drive Unlimited 2,use the plugin. I don't have motion data.please help me;[​IMG]
  16. noorbeast
    153,691Coins
    You need to be far more specific about what you have and have not done, plus let members know what hardware you are using and how it is configured.
  17. yjgogqqq
    yjgogqqq New Member
    河南省禹州市
    241Coins
    PLATFORM:window 7(x64),Steam
    1. opent SimTools_PluginUpdater.exe;
    2. drag TestDriveUnlimited2_Plugin.zip to the window of SimTools_PluginUpdater,then close SimTools_PluginUpdater.exe;
    3. run GameManager and GameEngine in Admin mode;
    4. in the window of GameManager,the content of first row choose the "Test Drive Unlimited 2";Second choose "Default"; Click the "Patching",then click the "Edit Path", choose path as "D:\Program Files (x86)\Steam\steamapps\common\Test Drive Unlimited 2",click the "Patch Game",then click "OK";
    5. Set the GameEngine as the official manual,then open the "SimTools-Tuning Center"
    6. run "TestDriveUnlimited2" in the steam platform;
    I cann't receive the motion data from the "Simtools",and I cann't see the data changes in the "SimTools-TuningCenter" when I have started driving the car;(ps: I can receive the motion data from the "Simtools",and I can see the data changes in the "SimTools-TuningCenter"when I play the game of "dirt3")
  18. noorbeast
    153,691Coins
    I don't have test drive unlimited 2 but the Steam version was working, so can you please advise what hardware you are using @yjgogqqq and post screen shots of your Interface and Axis settings.
  19. value1
    14,236Coins
    This resource has been removed and is no longer available for download.
  20. wolverine
    wolverine Wolver projectos
    Estudante
    Mozambique
    796Coins
    I installed tdu plugin but then what is happening doesn't appear in the plugin list. help me please
