Project : Sim racing
Discussion in 'DIY Motion Simulator Projects' started by Benjamin oh, Feb 20, 2016.
  1. piorck
    piorck Member
    french
    258Coins
    thanks for the person to move the sim !!
  2. Benjamin oh
    Benjamin oh Member Gold Contributor
    234Coins
    DC motor
    Hahahhahaha....
    I was moving it with my feet!=)
  3. Benjamin oh
    234Coins
    DC motor
    Date : 04 Aug 2016
    Change in Screen Stand design
    I will probably build a cabinet using the screen stand structure to store Steering wheels and extra sim racing equipment.
  4. DonCorleonez
    DonCorleonez Member
    195Coins
    keep it coming with update..:thumbs
    what is your motor gearbox?
  5. Benjamin oh
    234Coins
    DC motor
    Yea Sure..
    I am using motion Dynamic 200w 25:1 worm drive motor
  6. Benjamin oh
    234Coins
    DC motor
    Anyone here can advise me?
    Will 3D printer motor Mount work?
    I am on the verge of pre-ordering a 3d printer
  7. Nick Moxley
    17,056Coins
    No a 3d printed motor mount would likely be too weak, Unless you make it Crazy thick or beefy in places where as a simple steel mount would work just fine.
    3d printer's have their part, but super structural/needs to be strong stuff not soo much. At least within the reasonable priced printer range.
  8. Benjamin oh
    234Coins
    DC motor
    Okay Got it.... I will probably get my local workshop to fabricate a pair =)
    I will put the 3D Printer on hold first.
  9. Benjamin oh
    234Coins
    DC motor
    Date : 15th Aug 2016
    Custom Wheel plate to hardmount my T500rs
    Will probably use this till I save enough money for an Open Sim Wheel Kit.
    By Any chance can you guys suggest locations to Mount 5x of my Aura Bass shaker?
  10. Benjamin oh
    234Coins
    DC motor
    anyone can recommend me what I should I use for rod?
    1. Carbon fiber ?
    2. Aluminium ?
    Any suggestion on how can I attach a rod end on to these rods?
    151,979Coins
    +11,061 / 56 / -2
    Most use a metal tube with a nut welded wither end.
    @SeatTime used carbon fiber for his DIY actuator arms.
    I used solid aluminum rod for the short rods on my compact sim, which I tapped either end.
    Some have used profile aluminum bars.
    So I guess it depends on what material you prefer and are comfortable to work with, as all can be made to work.
  12. Benjamin oh
    234Coins
    DC motor
    Thank you @noorbeast.
    I think I will work with carbon fiber rod.
    I believe I need to machine out a pair of rod ends for each rod. By any chance does anyone know if interference fitting be able to secure the rods?
  13. noorbeast
    151,979Coins
    +11,061 / 56 / -2
  14. Benjamin oh
    234Coins
    DC motor
  15. Benjamin oh
    234Coins
    DC motor
    Some updates, will post more tonight
  16. noorbeast
    151,979Coins
    +11,061 / 56 / -2
    Quality craftsmanship :thumbs
  17. Benjamin oh
    234Coins
    DC motor
  18. Benjamin oh
    234Coins
    DC motor
    Video of it working :
    Well since 2 D.O.F is done , I am looking forward to start building a 6 DOF Simulator
    151,979Coins
    +11,061 / 56 / -2
    Great to see it all come together :thumbs
  20. Benjamin oh
    234Coins
    DC motor
    Thanks =)
    After reading up some 6 DOF Sim racing thread in this forum, I decided to start building my own Linear actuators. I have concluded that DIY linear actuators are the way to go for my apartment.Firstly my apartment have a maximum power output of 240V AC 13 AMP Per Room ( 312oW) and a maximum weight limit of 150kg/m^2 .
    These are my findings :
    and Ball screws :
    I am planning to use Saber-tooth board with a 24V Motor listed above (6000RPM and 0.6Nm of torque).
    Can you guys correct me if I am wrong :
    Linear speed = Pitch x RPM
    Power = Velocity x force
    If I were to use SFU 1604-4 (from above) I will have linear actuation speed of :
    4 x (6000/60) = 400mm/s?
    350 w = 0.4 m/s * Force
    Force = 875N
    and If Were to use SFU 1605-4I will have linear actuation speed of :
    5 x (6000/60) = 500mm/s?
    350 w = 0.5 m/s * Force
    Force = 700 N
