6 DOF simulator - chain / belt driven
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pit, Aug 2, 2016.
Thread Status:
Not open for further replies.
  1. Pit
    30,501Coins
    Since months I am pondering on a chain driven 6DOF. This thread is now reserved for future postings about an other kind of 6DOF which has - as far as I know - never build before. This can be realized in an easy way and should not to be too expensive. IMHO the chain / belt driven system can be very effective, very fast, less noisy and cheap(er than any former DIY actuator 6DOF). Stay tuned ;)
    • Creative Creative x 2
    • Optimistic Optimistic x 1
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Thread watched and good luck :thumbs
  3. SilentChill
    20,598Coins
    Exciting !! As always @Pit it will be very innovative if you build it :)
  4. BlazinH
    16,676Coins
    Sounds like a good idea @Pit.:! I will be interested to see how you end up connecting the chain to make an actuator.
  5. Pit
    30,501Coins
    :) Still fiddling and tinkering, need a better skill of SketchUp, but progress is not too far away from now :p
  6. Pit
    30,501Coins
    some progress, but pre alpha...
  7. Pit
    30,501Coins
    more progress, almost beta:
    chain actuator1.jpg chain actuator2.jpg chain actuator3.jpg chain actuator4.jpg chain actuator5.jpg chain actuator6.jpg
  8. RacingMat
    21,066Coins
    good project! nice drawings @Pit
    my 50 cents:
    - if the shear forces are too high (chain not aligned with bracket), you could use 2 rods with the chain in the middle
    - I think it will be noisy
    - where is the chain tensionner?
  9. Pit
    30,501Coins
    Thank you mate for your feedback
    IMO the guided rail should handle the forces.
    I think I will use belts
    +1
  10. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Ce système à l'avantage d'être robuste, mais sera bruyant et il sera très difficile de maintenir la chaine suffisamment tendue.
    This system has the advantage of being robust, but will be noisy and it will be very difficult to maintain sufficiently tight chain.
  11. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,799Coins
    With PMDC motors a gearbox will be needed.
  12. Pit
    30,501Coins
    first of all I will choose a belt driven system, second the motor is a standard 24/36v geared motor nothing special. The motor on the photo is only for demonstration only
  13. BlazinH
    16,676Coins
    I don’t have any experience using linear bearings but I would be a little concerned about the side forces put on a single bearing and it holding up over time. Even if you don’t think a second rod is needed, I would consider adding a second linear bearing an inch or two above or below the main bearing. The second bearing wouldn’t necessarily need to be attached to the belt, but firmly linked to the main bearing to help keep it aligned so the side force stresses on the main bearing are minimized and shared by the second bearing which will have more leverage against side forces.
  14. Pit
    30,501Coins
    rgr :)
  15. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    My first simulator had a chain ,a steel rod and a geared 1/2HP AC motor ... see next video to have a fast good look ... maybe a shorter one would be effective with you .
    • Like Like x 6
  16. Pit
    30,501Coins
    OMG, of course Speedy our Ingenieur of DIY did it already, nice to see how you designed it. :) I'll try to create a less complex (big) design but close to yours.
  17. speedy
    Alexandria , Egypt
    7,944Coins
    Now I'm sure it's in the hands of a better DIYer ... :cheers
    - The chain tensioner is the motor mounting plate itself ... just untighten its slotted 4 big bolts and the gravity would do the rest ... or left the motor about 3cm up to have enough space to unhook the chain .
    - The top Sprocket bridge could be beside any of the top teflon aligning rings ... I put it beside the bottom one to have the maximum movement control over the steel bar and to give a longer motion range .
    - Use the other chain center to mount a piece or two of rigid plastic to gain a stop point with a limit switch .
    Good by Gina !!!
  18. RacingMat
    21,066Coins
    if there's something to smoke, Pit is our man!
    • Funny Funny x 4
Thread Status:
