Showroom My First 2dof Seat Shaker Build w/Complete Shopping List
Discussion in 'DIY Motion Simulator Projects' started by pittperson, Jun 29, 2016.
  1. pittperson
    pittperson Member
    North Carolina
    550Coins
    I've been browsing this forum off and on for the past year and finally decided to take the plunge. I plan on keeping this thread up to date with as much info and as many pictures as I can to hopefully make it a one stop shop for all future first timers.
    Shopping List
    Main components:
    Miscellaneous components:
    Useful Links
    I've done a bit of pre-gaming with some earlier threads (thanks to all of those who have already helped!). I expect I'll have some future specific threads so I'll keep those linked in this post along with the threads I find that answers questions:
    Tools
  2. pittperson
    pittperson Member
    North Carolina
    550Coins
    7/24/16 - Lots of Progress Today
    153,728Coins
  4. pittperson
    pittperson Member
    North Carolina
    550Coins
    Is there anyway to remove the shaft from the motor and reverse it? I have the motors from pgsaw on ebay.
    153,728Coins
    You can easily knock out the rivets, split the gear case and turn the shaft around, then bolt it back together. I am pretty sure others have had no issues with doing that, but I did have problems with a 60:1 gearbox where I reversed the shaft.
  6. pittperson
    pittperson Member
    North Carolina
    550Coins
    More progress...
    I had a hard time reversing the motor shaft. I couldn't bang it out for the life of me. I ended up having to rent gear puller which did the trick.
    7/25/2016 - Finished the frame
    8/2/2016 - Got the motors mounted to the frame
  7. hoopstar
    hoopstar when 10/10ths isn't enough..
    Electronic Engineer
    Adelaide
    49Coins
    Any links to how this was done Noorbeast?
    I'm very much in the planning phase of my sim upgrade and would like to incorporate this mod in my design.
    153,728Coins
  9. hoopstar
    Electronic Engineer
    Adelaide
    49Coins
    Oh, very nice..
    I have some questions I'll ask in that thread.
    Paul
  10. pittperson
    pittperson Member
    North Carolina
    550Coins
    I had screws where noorbeasts rivets were so it was just a matter of unscrewing the case and opening it up. The hardest part for me was getting bearing off of the shaft which is where the gear puller came in handy.
  11. pittperson
    pittperson Member
    North Carolina
    550Coins
    8/9/2016
    Big milestone today. Finished off the levers on the motors. All major welding is done.
    Next step, clean and paint the frame.
    153,728Coins
    What is the Center To Center distance on the levers, it looks pretty big?
  13. pittperson
    pittperson Member
    North Carolina
    550Coins
    Center to center is 3.5 inches. Should it be shorter?
    153,728Coins
    That is about 90mm. By all means try it, but if the motors struggle at all then try around 60mm.
  15. pittperson
    pittperson Member
    North Carolina
    550Coins
    Nice, thank you. I will definitely keep this thread updated on how well they work.
  16. pittperson
    pittperson Member
    North Carolina
    550Coins
    All primed and ready for paint...
  17. pittperson
    pittperson Member
    North Carolina
    550Coins
    8/13/16
    - Frame all painted
    - POT mounts created (used some 1/8in aluminum and twisted it, cut down the hex drive screws and connected the two with some rubber tubing to create these)
    Unfortunately I fried one of my JRKs so work is on hold until the new one shows up.
  18. pittperson
    pittperson Member
    North Carolina
    550Coins
    8/17/16
    It's alive! Next steps
    - Clean up the wiring
    - Create protection for the JRKs
    - Mount power supplies and JRKs to a solid base.
    153,728Coins
    Congrats, it is always a mixture of excitement and relief when you finally get your brand new rig moving for the first time :thumbs
  20. pittperson
    pittperson Member
    North Carolina
    550Coins
    8/24/16
    Built a couple fan mounts/JRK protectors with some spare parts.
