My 2DOF Sim project
Discussion in 'DIY Motion Simulator Projects' started by Mo165, Nov 11, 2015.
  1. Mo165
    Mo165 Member
    Austria
    103Coins
    Hello here i'm showing my DIY 2DOF project
  2. Mo165
    Mo165 Member
    Austria
    103Coins
    Got my Motors after 3 weeks from Canada.
    How can i change the rotation direction?
    153,722Coins
    I am not certain what you mean by "change the rotation direction".
    Do you mean how is the motor wired to the controller and pot so that altering the pot changes the motor direction, if so it is like this: http://www.xsimulator.net/community/attachments/jrk-wiring-jpg.16435/
    Or do you mean how do you change the gearbox so there is a left and right configuration, in which case you disconnect the gearbox from the motor, unbolt the gearbox 2 halves, turn the main gear over and bolt it all back together.
  4. Mo165
    Mo165 Member
    Austria
    103Coins
    I mean the gearbox thanks! ;)
  5. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    I'm not sure why you would need to mess with the gearbox unless you had some extreme space constraints. The motor will spin both directions by reversing voltage (switching the red and black wire). Your controller (JRK, MonsterMoto, etc.) will do that for you. But to try it manually just switch the wires to your 12V power.
  6. Nick Moxley
    You open the gear box and swap to keep thing's Symmetrical, plain and simple. That is unless you want thing's to be a little "wonky" on the motor placements on an other wise square frame.
  7. Mo165
    Mo165 Member
    Austria
    103Coins
    Today I changed the gearbox on one motor.
  8. Mo165
    Mo165 Member
    Austria
    103Coins
    And I've got the motor mounts!
  9. Mo165
    Mo165 Member
    Austria
    103Coins
    Hello I´ve already build my motion sim and installed simtools and patched Project cars, but the motion doesn´t work in the game.
    Does someone know what the problem could be?
  10. Mo165
    Mo165 Member
    Austria
    103Coins
    When i do the DOF Output test at Simtools nothing work.
  11. Mo165
    Mo165 Member
    Austria
    103Coins
    Or can i switch the motion on in Project cars?
  12. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Hi Mo165, to be able to help you out, we need a bit more info.
    What are your jrk config settings for example?
  13. SeatTime
    Recommend you start a project thread to explain/show members what you have built, then you may have a chance of getting help.
  14. Pit
    30,510Coins
    Yep, look at shared memory or something else, must be enabled.
  15. Mo165
    Mo165 Member
    Austria
    103Coins
    My 2 DOF Sim is already done.
    But still i can´t take it in the game. :/
  16. Mo165
    Mo165 Member
    Austria
    103Coins
    Can someone help me?
    I´ve patched project cars already and made Settings for the game engine but it still does not work.
  17. Mo165
    Mo165 Member
    Austria
    103Coins
    Thanks i´ll take a look!
  18. noorbeast
    153,722Coins
    What control boards are used?
    Can you confirm if your sim moves correctly in Output Testing.
    Can you please post pictures of all settings.
  19. Mo165
    Mo165 Member
    Austria
    103Coins
    I´ve got two Pololu JRK12V´s.
    The Output testing is only at pololu correctly not at Simtools.
  20. Mo165
    Mo165 Member
    Austria
    103Coins
    Ive got the similar Simtools Settings as Erwan960 ;)
