test simtools+stepmotor
Discussion in 'DIY Motion Simulator Projects' started by Bordiin, Jul 25, 2016.
  1. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I was thinking about this Nema motors...
    As always, there is a trade-off, they have lots of torque, but kinda slow, if you want them to get fast, they loose torque.
    So, you can use higher pitch screw (10mm pitch in this case) than common dc motors to get a little more speed until some point.
    @Bordiin , I think if you add a pair of gas struts to release some weight from the motor, you can get even faster response.
  2. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
    Yes they are really strong, i tried use nema 23, but i have some problems with torque in high speed, maybe the SCN5 or SCN6 the are using a drive to microstep, so you can reach more speed without loss of torque.
  3. Bordiin
    Brazil
    159Coins
    Maybe, i need think about, and find the best place to put the gas struts. but know i think that the motor can lift 150Kg, with this speed, but i will test later and informed you :D
  4. Bernd Manger
    Bernd Manger Active Member
    Measurement and control mechanic
    1,055Coins
    Hello Bordiin,
    I don't know which nema23 is used in the SCN6.
    On this site are many of them available, even up to 3Nm.
    http://www.omc-stepperonline.com/stepper-motors-nema-23-stepper-motors-c-1_22.html
    Here are 4 pictures of a data sheet from another provider showing some torque curves. There are models for lower or higher speed.
    nema 23_Seite_1.jpg nema 23_Seite_2.jpg nema 23_Seite_3.jpg nema 23_Seite_4.jpg
    Have you thought about moving as well the pivot point as the motors closer to the balance point of the rig.
    So you need less movement (speed) of the actuators to reach the same swing amplitude of your rig.
  5. Bordiin
    Brazil
    159Coins
    @Bernd Manger I need test, but i'm thinking in build other actuator and put in front, or change use 2 in front and 1 in the back,
  6. LI JIAN HUI
    LI JIAN HUI Learn 2DOF maker
    CHINA
    351Coins
    2DOF, DC motor
    Feel a little noise, it sounds normal? Do you have any influence on the game?
  7. Bordiin
    Brazil
    159Coins
    It's normal, because the high speed.
  8. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    The stepper motors must give a good shimmy action. What plug in are you using for your game? Or is that a default (the one that it came with)
  9. Bordiin
    Brazil
    159Coins
  10. Bordiin
    Brazil
    159Coins
    After a while here it's my final project :D
    • Like Like x 8
    • Winner Winner x 4
  11. obobo
    obobo Active Member
    1,323Coins
    nice form
  12. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    nice to see someone using stepper motors:thumbs
  13. xiejin
    xiejin New Member
    CHAINA
    94Coins
    Nice
  14. pab61
    pab61 Member
    Adelaide
    638Coins
    This is great, thanks for all the info Bordiin. I'm looking at adding a seatbelt tensioner and wheel mover to my sim rig (I cant move the seat, my rig is too heavy (although, seeing yours has got me thinking, I've seen 13Nm Nema 34 Motors are available, imagine what they'd be capable of lifting!) so rather than build a seat mover I was planning to move the wheel instead) (will start up a build thread soon). Was looking at stepper motors and was wondering how strong I'd need them to be, seeing 3Nm motors lift your whole rig makes it pretty clear that motors like this will be more than enough to make the seatbelts tight, and move the wheel back and forward on sliding rails.
    One question (for Bordiin, or anyone else who knows), looks like the motor drivers are the same or similar to the ones I was looking at, they don't interface directly with the PC do they, I'll need an Arduino between them, is that right?
  15. Bordiin
    Brazil
    159Coins
    Hello @pab61 Yes you'll need one arduino to axis and one interface in simtools for axis too.
  16. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    By all means post in your native language, but please also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    There is a specific section for native language based social interactions: http://www.xsimulator.net/community/#international-social-chats-and-conversations.155
  17. Bordiin
    Brazil
    159Coins
    testing the strength of the motors. with 135kg. and my new toys to improve my simulator :D
  18. yobuddy
    51,183Coins
    Very, Very Nice Looking rig @Bordiin!!
    Well done buddy!
  19. xytras
    xytras Member Gold Contributor
    germany
    587Coins
    Hmm steppers were the first thing that came to my mind when I started with my 2DOF. Since it is pretty difficult to get some good motors for a reasonable price here these steppers seem to be a good choice.
    There are 13Nm steppers available around 100 EUR and with driver around 140 EUR. There are cheaper TB6600 / 5A boards available but I guess they would burn. What driver is used here ?
  20. Bordiin
    Brazil
    159Coins
    Hello @xytras, I'm using a 3Nm steppers I paid 60 EUR (http://www.kalatec.com.br/motor-de-passo-5034-349) the specification of the motor and the drive the company recommend this one (http://www.kalatec.com.br/drive-de-motor-de-passo-str8) I paid 200 EUR. STR8 is for 8A, it's a little bit expensive but is one of the best drive here in brazil.
    You need to check the current of the motor. And with you use the motor only to move de seat not all frame like me you can build with a nema 23 and use this TB6600 board
