How to: ?? Slack in my 2 dof simulator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Simon Husum, Aug 16, 2016.
  1. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    Hi guys.
    I have a question..
    I have a 2 dof seat mover and when i sit in my seat there seems to be a bit of slack sideways in the seat. Approx. 2-3cm to each side.
    My lever arms are completely stable. So the slack is from the construction.
    No slack front/backwards.
    Any ideas how this can be solved? :)
    Perhaps something like the one in the attached picture?
    (The first picture is from my setup so you can see how it is now)
    Regards Simon
  2. Nick Moxley
    CV joints tend to have that "rotational" side effect....Yes the Bar eliminate that. or swap out the pivot for a U joint with no additional movement.
  3. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Wow.. Thanks for the prompt answer @Nick Moxley :thumbs
    Have attached a picture of it..
    Can see that it actually will do quite a difference.
    But my brain doesn't understand it in all its glory.. :(:)
    Won't the motors have to push a bit harder and use more amps with the bar attached as the motors would have to "force" the seat through/over the "neutral zone"..
    Or is it just me? o_O
    153,728Coins
    A properly designed Panhard style rod will eliminate the wasted energy use in torsional twist: https://en.wikipedia.org/wiki/Panhard_rod
    The rod will need to be more substantial than rod ends tapped to an allen key, though I gather that is for mock up purposes only.
  5. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Thanks @noorbeast ;)
    Didn't know it was called a Panhard rod.
    Haha.. Yes indeed. It was only for illustrating.
    Don't think the tape and allen key will do much justice if it was mounted like that..
    But tried today to mount it with tape.
    Tried a lot of places today to mount the rod temporarily. But when the seat changes the rod ends isn't alligned the same place.
    So that will cause the seat the have very reduced movement?
    Guess I have to calculate exactly where to mount it and what length it is going to be? Right?
    Asume it has to be outside the joint as showed in the picture?
    153,728Coins
    A substantial diagonal between the bottom frame and seat is likely needed, depending on the geometry already involved.
    Replacing the CV joint with a universal joint will eliminate torsional twist, which is why most of us run universal joints.
  7. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    Thanks for hour reply @noorbeast ..
    I have read further about a universal joint.
    I think that is the way to go instead..
    I can see that has slupoed by in the preperatiln when I made it..:blush :)
    Thanks for the "assisstance" :)
