Jeroen's wipermotor powered SimforceGT
Discussion in 'DIY Motion Simulator Projects' started by Jeroen, Dec 7, 2008.
  1. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
    Hi all,
    Here I will keep my home made SimforceGT project up to date. First some specifications...
    About the frame:
    I used about 15m 30x30 metal bars to weld the frame. frame lassen 1.JPG frame lassen 2.JPG frane lassen 3.JPG
    Dimensions of the frame:
    - 150 cm lenght
    - 75 cm width
    - 60 cm height (steering wheel)
    Used equipment:
    - fast pc
    - hitachi 37 1080p screen
    - logitech g25 steering wheel
    - seat from a honda crx (soon replaced)
    - creative 5.1 speakerset
    - 2 wipermotors
    - 40A powersupply
    - Thanos's avr-controller 1.5 and h-bridge 1.2b
    The next pictures will show the assembled and painted frame:
  2. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    He should better wait to post dimensions, as I think he needs to change them slightly, later.
    The upper joint bar has to be placed in touch with the seat. As well the seat has to be fixed tight to that bar.
    Otherwise the seat will shake horribly and some frequencies of acutator rumling will cause hefty resonances.
    Regards
    Christian
  4. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
    @ Sirnoname
    You are absolutly right, I'm a newbie at forums. I will keep my project up to date.
    That was the plan when i finished the frame. And if somebody has questions, i'm
    glad to help.
    @ Egoexpress
    I've tested the wipermotors with a buddy of mine who weighs about 100 kilo's and
    everything works just fine although the motors only turn in circles. Seatbelts are almost
    needed.
  5. RaceRay
    Hamburg, Germany
    23,876Coins
    Hi Jeroen,
    would be fine, when you could repair your broken pictures at
    <a class=postlink-local href=http://www.x-simulator.de/forum/post11271.html#p11271 target=_blank>post11271.html#p11271</a>
    regards. René
  6. robert
    robert New Member
    holland/ amsterdam
    405Coins
    3DOF, Motion platform
    hey Jeroen,
    Ziet er goed uit ,heb je de sim al werkend? :clap:
  7. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
    Hoi,
    Ben een heel eind. Mis nog een paar onderdelen en dan kan ik gaan testen.
  8. Swets
    Swets Member
    PLC Programmeur
    Holland/Krimpen a/d IJssel
    375Coins
    hee... nederlanders....
    leuk... welke electronica hebben jullie?
  9. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
    hoi,
    Ik ben de controller van Thanos aan het bouwen... bijna klaar. En dan hopen dat alles in orde is. Ben benieuwd hoelang de motoren het uithouden en hoe de effecten zijn.
  10. Swets
    Swets Member
    PLC Programmeur
    375Coins
    wel een filmpje posten hoor....
