AMCI Resolvers for positioning?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Slider, Aug 12, 2016.
  1. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    Hello all knowing ones... :)
    I have at work these resolvers which are highly accurate (apparently) and i was wondering if they would be suitable to use for positioning in our sims? They have a few more wires than a normal pot etc.
    https://www.amci.com/plc-automation-products/r11-size-11-brushless-resolver-sensors/#!/194
    https://www.amci.com/files/8514/5496/8748/r11x-n10-7-2t510.pdf
    https://www.amci.com/industrial-automation-resources/plc-automation-tutorials/what-resolver
    Let me know what you think!
  2. Deleted member 10067
    We need position resolvers, also a way to interface to the ard. I'd be all over this.
  3. SeatTime
    Not as simple as it may look, look forward to your solution.
  4. Deleted member 10067
    The main problem I had was the feedback pots. Resolvers would be soo much nicer. I'll look for a single chip solution.
