Showroom Budget Steel 6dof w/ MM (Now Sabertooth 2X60), Arduino, Chinese 12v Motors
Discussion in 'DIY Motion Simulator Projects' started by CLEOPHUS, Sep 3, 2016.
  1. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Hi Everyone,
    I thought I would post my build. The idea was to create a budget 12v machine made from steel, using Monster Motos, Arduinos, and 12 Motors from China. I've never welded in my life, but I thought I could do this.
    Unfortunately, I don't have pretty schematics or plans - but I have used what I have learned from here to develop my own idea. Many thanks to others that have posted here and have influenced me. ( @SilentChill - largely borrowing from his design, @Pit for the MM diagrams, and everyone the keeps the FAQ up to date. )
    Here are the items I have purchased:
    12
    Monster Moto driver
    http://www.ebay.com/itm/191674295987
    $71 USD
    12
    Northbridge Coolers
    EBAY
    $60 USD
    6
    Arduino Uno R3
    MicroCenter
    $36 USD
    6
    M5 Set Screws (connect 2nd motor shaft to the flex coupler)
    http://www.ebay.com/itm/141837930169
    $4 USD
    6
    Flexible Couplers - 5mm to 6.35mm (Connect set screw to Hall Sensor)
    http://www.ebay.com/itm/331204345803
    $21 USD
    Aurasound Bass shaker
    http://amzn.to/2bLltNi
    $50 USD
    Lepy Bass Shaker Amplifier (68w)
    http://amzn.to/2c2csfx
    $25 USD
    6 Port USB Hub
    http://amzn.to/2bXJknK
    $8 USD
    6
    12V - 350 Watt Dual Shaft motors. 50:1, 72RPM. 20mm keyed shaft with 5mm center hole
    https://dakemotor.en.alibaba.com/pr...2V24V_250W_worm_small_gear_reducer_motor.html
    $600 USD
    6
    HP 1000w server power supplies
    http://www.ebay.com/itm/111656748093
    $132 USD
    6
    1/2 Threaded Rods (24 inches long)
    https://www.zoro.com/value-brand-threaded-rod-carbon-steel-12-20x2-ft-u203600502400/i/G3453764
    $18 USD
    12
    1/2 Female Rod Ends
    https://www.zoro.com/qa1-female-stud-rod-end-rh-12-20-cfr8s/i/G5201393
    $70 USD
    Lightweight Fiberglass Racing Seat
    https://thmotorsports.com/nrg-innovations/nrg-seats-frp-bucket/frp310/i-287094.aspx
    $190 USD
    Rectangle Metal Tubing for Base - 2" x 4" x 1/4" - 84" long
    http://www.speedmetals.com/
    $96 USD
    6
    Square Metal Tubing for Top - 1 1/4" x 1 1/4" x 1/8" - 84" long
    $60 USD
    6
    Hall Sensors (180 Degree BI TECHNOLOGIES 6127V1A360L.5FS)
    https://www.arrow.com/en/products/6127v1a360l.5fs/bi-technologies
    $73 USD
    6
    20mm Ridgid Steel keyed Couplings
    https://www.globalindustrial.com/p/...ling-wkeyway-mrc20kw4h90-black-oxide-20mm-5pk
    $95 USD
    1-inch Angle steel for motor mounts
    http://www.lowes.com/pd/The-Hillman-Group-6-ft-x-1-in-Hot-RolLED-Weldable-Steel-Solid-Angle/3059249
    $27 USD
    1.5 inch Steel Flat Bar 1/4 inch thick X 4ft long (For lever arms)
    http://www.lowes.com/pd/The-Hillman...-RolLED-Weldable-Steel-Metal-Flat-Bar/3059235
    1.5 Inch Angle Steel for Rod End Mount
    http://www.lowes.com/pd/The-Hillman...Hot-RolLED-Weldable-Steel-Solid-Angle/3059245
    $13 USD
    I decided to weld the unit together first and test fit to see how it felt.
    Base: (2" x 4" x 1/4" rectangle steel with wood furniture legs I had laying around for height)
    Top: 1 1/4" square tube (Sorry for the mess)
    Dry Fit:
    IMG_20160808_225421.jpg IMG_20160808_225436.jpg IMG_20160808_225447.jpg IMG_20160809_074404.jpg IMG_20160809_074418.jpg
    I'm currently working on wiring up the electronics and will post more progress soon. I will gladly post some specific dimensions if needed.
    More to come soon.
    UPDATE:
    Here are the videos posted later in the thread.
    • Like Like x 15
    151,985Coins
    +11,061 / 56 / -2
    Very neat work indeed :thumbs
    Just a quick question, why are the levers mounted to the inside as it looks like there is a fair angle on the rod ends?
  3. CLEOPHUS
    CLEOPHUS Member
    229Coins
    I'm not committed to them being mounted inside, but I will say that the angle does seem more dramatic in the photos. Also, the motors have not been calibrated so some of the levers are in a position they will never experience while working.
  4. SeatTime
    Nicely built:thumbs. From the photos I have some concerns, but maybe see how it pans out.
  5. SilentChill
    20,590Coins
    Glad I inspired someone else :D
    Just a couple of observations, however I maybe wrong :p
    I think you may have problems with the front 2 levers hitting the foot pedal frame. Probably need to move the frame a good 100mm inwards either side. Tried to show what I mean in pic below
    Also you may need to get the arms a bit further out from the levers else they might bind in the lower position of the axis and end up bending the arms.
    I learnt the hard way just trying to help :D
    look forward to seeing the build progress
    • Useful Useful x 3
  6. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Craig - I fear you're right, but still holding out hope. I'm just finishing what seems like miles and miles of wiring. It takes a tidy build to a complete mess quickly. I'm learning from my mistakes. Last night I couldn't figure out why 3 of my motors wouldn't operate properly with SMC Utils. I realized that all 3 were mounted in the same way/direction. Reversed polarity on them and they are operational now.
    Also, I have mounted the northbridge coolers on the Moto's and only 1 of 12 caught fire! Progress! haha
    After I swap that one out - I will post some updated pics.
    Cliff
  7. CLEOPHUS
    CLEOPHUS Member
    229Coins
    During testing - I caught 4 more Monster Motos on fire due to PWM set too high. Unfortunately, I wont make much more progress until I have replacements.
    Bolted in the seat and added some wood.
    • Like Like x 6
  8. Pit
    30,490Coins
    looks very promising, almost done, hold it on mate! :)
  9. Pit
    30,490Coins
    one more thing: with the seat in the middle you will cover the electronics, so if something is going wrong with your MMs etc., then do you have to disassemble the seat?
  10. RacingMat
    21,047Coins
    congrats for the work being done so far!
    i'm concerned about rigidity of these brackets:
    .jpg
    It's great to have an "Evolution saw", the cuts are near to perfect :)
    It helps very much to weld more easily !
    Your first welding are bulky... probably too cold (not enough current) or too fast
    http://www.wcwelding.com/arc-welding-tips.html
    try to cut some welding you made and have a look on penetration :) that's a good exercice
  11. SilentChill
    20,590Coins
    I can pretty much guarantee 99% nothing to do with PWM settings it's poor MM clones.
  12. CLEOPHUS
    CLEOPHUS Member
    229Coins
    As I said - It was my first time welding, but they did improve as I went. I did cut a bunch of my practice welds to see penetration and they seemed plenty deep. I considered eliminating the brackets all together and just running the rod ens through the frame, but I couldn't easily find rod ends that were long enough.
    If I could recommend anything to someone looking to build with steel - the 10" Evolution saw is amazing. I cut 1/4" steel 2x4's for the base just as fast as I would cut a wood 2x4 with my dewalt saw. Out performs my dewalt saw I spent 3x more $ on.
    Cliff
  13. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Craig - Did you keep using the Chinese MM from ebay or did you order the DX.com or actual sparkfun versions for your sim?
  14. SilentChill
    20,590Coins
    I have bought from Ebay, AliExpress and from Amazon. All hit and miss
  15. CLEOPHUS
    CLEOPHUS Member
    229Coins
    So - some news. You were exactly right Craig. Check it out:
    After bending several threaded rods, I came to the realization that you were right and made the modifications. Much better now (still need to replace a rod or two)
    Reversed the levers for stability, added struts, etc. Should do full testing this weekend.
    Cliff
    • Like Like x 8
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    looks good cant wait to see a video. your almost there. if your rods keep bending you can slip some tubing over them.
  17. CLEOPHUS
    CLEOPHUS Member
    229Coins
    They were bending because they were hitting the metal before I modified it. Anytime there was yaw or sway involved - bad noises resulted.
  18. SilentChill
    20,590Coins
    Glad I'm of some use to someone :p
    Cool to see a video once you have it going properly
  19. RacingMat
    21,047Coins
    nicely done and your painting is great! I like the finish :)
    can't wait to see the video :popcorn
  20. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    • Funny Funny x 7
