Tutorial Another simple arduino dashboard with TM1638
Discussion in 'DIY peripherals' started by vthinsel, Sep 22, 2015.
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Here is a short tutorial explaining how to build a simple dashboard using an arduino nano together with a TM1638 module. As I got a couple of issues, I decided to make a simple tutorial out of it.
    The TM1638 module chosen (bought from DX) provides
    - 8x 7 segment digits
    - 8x push buttons
    - 8s bicolor LEDS (nice for RPM !)
    The arduino chosen factor is the nano as it is smaller, so easier to integrate into a nice dashboard. We will see this brings soem more challenges, especially around power supply
    Step 1 : Prepare the TM1638 and arduino nano
    Chances are the TM1638 module and the arduino will arrive with pin headers already soldered. I found some nano without the pins mounted, but couldn't find TM1638 without the headers. For a nice and tight integration, the headers will have to be removed, especially onthe TM1638 as the headers are on the top part. This is quite easy : insert a small screwdriver to start lifting the plastic header, and finish removing it with a plier.
    Once the plastic header is removed, you can melt the solder pads with the pin and remove the pin with your plier. Easy, if not done in hurry.
    So now you have your arduino nano and your TM1638 "naked"
    At this stage, you can upload the sketch to the arduino nano.
    Step 2 : Powering the TM1638
    When I first received my arduino nano, I juste replaced my uno by the nano including the power leads that were going from the uno to the TM1638. Biiiiiip. The nano started to smeel bad, together with some smoke. The reason is simple : the +5V available from the nano is in fact coming from the USB/serial converter on the nano board , a FT232. Unfortunately, the TM1638 draws more power than the FT232 can provide :(
    So the solution is to power the TM1638 directly from the USB header. You will need to solder one wire from the +5V USB pin directly to the TM1638. This can be done more easily from the nano PCB by taking the +5V from the capacitors or zener as shown below:
    Step 3 : wire arduino and TM1638
    Now, wire 4 more cables from the arduino to the TM1638: GND to GND ,Pin 3 to Strobe 0 (STB0,) , Pin 4 to Clock, Pin 5 to Data.
    I used a glue-gun to secure the wires and the arduino nano!
    Step 4 : upload sketch to arduino
    If you haven't done so before, you should upload the sketch to the nano. When upload has finished, the TM1638 should display "CarDashX". Good.
    Step 5 : casing
    If you have a 3D printer, you can use the attached stl/sketchup files (check the USB port, which may be different depending on where you sticked the nano on the TM1638)
    In the attached zip file, you can find the sketchup model + stl file as well as the arduino sketch. For more details on the arduino sketch you can check the cardashx topic somewhere in the arduino projects.
    • Like Like x 8
    • Winner Winner x 5
    151,480Coins
    +11,041 / 56 / -2
    Great project and overview @vthinsel, you make it real easy for others to follow in your footsteps :thumbs
    • Agree Agree x 4
  3. RacingMat
    21,040Coins
    Great!
    too bad for the smoke... and thanks for sharing with us!
    Maybe you could add some words about GameDash setup?
  4. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
  5. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Nice project, i'll try it for sure. Thanks.
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
  7. jaco73
    jaco73
    thanks for sharing, will be very useful: Cheers
  8. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Argh..... sometimes google sucks. They changed the sharing options. I can't include links anymore to specific pictures of an album :(
    So I changed and updated the pics directly in the post. Less dynamic, but more change proof from Google.
  9. Dmraf
    Dmraf New Member
    Ufa, Republic Of Bashkortostan, Russia
    174Coins
    Thank you!:)
  10. jays
    jays New Member
    Taiwan
    252Coins
    He is also using simtools get game data? Or there is another easier way ?
  11. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    For the moment being, it uses simtools. When I have time someday, I'm thinking of a simple standalone networked box based on UDP (not Wifi). Maybe a raspberry would do the job nicely like this http://www.mjoldfield.com/atelier/2012/08/pi-tm1638.html
    With a nice web GUI to configure it to match games specifications......
  12. maphf60
    maphf60 New Member
    - 507Coins
    Hello, here is a TM1638 module is by myself
    Dashboard with an Arduino Nano, a 7-segment display for Gear (characters height 57 mm, working 12v), 2 displays 4 digits 0.36 '' (rpm and speed) and ramp LEDs for Rpm.
    Display driver for GEAR directed by optocoupler (tlp 181, € 0.13 / ebay).
    The circuit integrated TM1638 costs 0.327 € / ebay.
    Display 7 digits 57mm red € 5.90 / Gotronic (France)
    equivalent products on ebay
    code used CarGashX
    Assetto Corsa: Gear works (but not in the right Endroid) but not the rest
    Dirt Rally: Rpm works but not the rest
    and PCARS: nothing (installed the plugin "ProjectCar Alt" and to patch the game are asked to select a directory with an empty file called Expired PCARSUDP.txt I not found)
    Can help me find the solution, I installed various plugins
    Thank you to all
    [​IMG] [​IMG]
  13. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    First thing to check is on GameDash. Do you have values displayed correctly in GameDash ?
    Your pictures are broken.
    Are you running on PS4 / PC ?
    The file pcarsudp.txt is a file you have to create manually as detailed in the instructions of the plugin.
  14. maphf60
    maphf60 New Member
    - 507Coins
  15. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Nice PCB/routing.
    I guess your big 7 segment mimics one of the 8 others ?
    I see you have only 3 buttons. Which ones are you using among the 7 that I use (choose left/choose right/save) ? I'm afraid that your design may be different from stock TM1638 yo can find on ebay/ali/.... so I can't really help. As an example you used LEDs of different colors: The TM1638 module I use has dual color LEDS which are driven by the code/TM1638 so clearly the code will have unpredictable on the RPM leds behavior, and probably other
  16. EduardoMoreira
    EduardoMoreira Member
    113Coins
    Gerar. ..thanks to sharing.
  17. Quertreiber
    Quertreiber New Member
    Eppingen-Germany
    361Coins
  18. maphf60
    maphf60 New Member
    - 507Coins
    Hello vthinsel and thank you
    PCARSUDP.txt: I do not understand what to do
    test with Arduino Nano and TM 1638 standard module (with bi-color LED)
    Dirt Rally:
    Dash1 - Speed / dash2 - Gear / Dash3 - Rpm
    power - on Gear display and LED digit pad for Rpm
    Assetto Corsa:
    Gear and Rpm display digits but not on LEDs for Rpm
  19. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    For the led rpm have you tried the reset button ?
    The problem probably comes from dual color led which are assumed by the code. Try to change the number of red leds using the buttons.
  20. vanty200419
    vanty200419 New Member
    Việt Nam
    195Coins
    DC motor, Arduino, Joyrider, SimforceGT
    good thank you
