Help with creating a plugin
Discussion in 'SimTools Plugins' started by yasayanbalyoz, Aug 30, 2016.
  1. yasayanbalyoz
    yasayanbalyoz New Member
    Turkey
    165Coins
    I am trying to get telemetry from a game via Memory Hooks and write a plugin. I found the pointer results of roll, pitch and speed. While writing the plugin ı am writing the
    Private Const _MemHook_Roll As UInteger = &H12380F8
    pitch value which is 012380F8 from the
    "game_name.exe"+012380F8.
    But roll has the same adress "game_name.exe"+012380F8 like pitch. Difference is the offset values which is in the change adress menu on top of the "game_name.exe"+12380F8
    Result is SimTools doesn't read any data from the game.
    What am i supposed write as offset values?
    Thank You.
    I can provide photos if im not understood.
  2. yasayanbalyoz
    Turkey
    165Coins
    Forget to mention, Cheat Engine properly shows the values everytime with no problem.
  3. SilentChill
    20,601Coins
    You have to add the offset on the next line for simtools to read it. If it has more than 1 pointer you need to add each on a seperate line.
  4. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    How is the custom plug in coming along? It looks like writing one can be quite a challenge. Would you be willing to mentor us if we need some help on ours? Best of luck in any case on yours.
  5. SilentChill
    20,601Coins
    What game you making a plugin for ?
