How to get roll, pitch, yaw in Simtools to QT?
Discussion in 'SimTools DIY Version' started by kazhoang, Sep 15, 2016.
  1. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    Please help,
    First, Sorry with my English.
    Can someone help me how to get roll, pitch, yaw and the others coefficient?
    I don't know how export Data to *.doc or QT.
    154,759Coins
    +11,213 / 57 / -2
    Can you explain what you are trying to do with the data?
    Something like the existing joystick plugin can save a sequence of data, but there is currently no way to play it. Once SimTools 2.0 is released work will commence on built in recording and playback functionality.
  3. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    I already have the way to control 6dof mini with Roll, Pitch, Yaw, X, Y, Z by using Controller(QT).
    Now all i want to do is get that data from the game.
    Then i push it into Controller (QT).
    With my configure about 6dof mini (Servo arm length, Angle at which the servo arm lies(Degrees), Platform Radius....), i control servo's degree depend on data that i just get.
  4. eaorobbie
    20,506Coins
    There is a maths plugin coming to V2 that will control 6dof , internally via simtools , there will be no need for maths to be done outside of simtools.
  5. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    OK, thank for your help. I already solve my problem, but i still wondering about "Axis Assignments" in Simtools. I finding a document to use that. But look like it not easy to understand ( like how to configure Dir , Force, % , Flt, ... ), so can you help me with that.
    154,759Coins
    +11,213 / 57 / -2
  7. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    Thank, i'll read and try to understand it.
  8. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    I also have the question,so it is no way to get the original roration data form simtools interface?
  9. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    Do i understand right? You ask for how to get exactly roll, pitch, yaw, x,y,z data from simtools interface , or how to use data from simtools for other project?
  10. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    My motion seat is control by roll, pitch, yaw,so i want to get the data ,not asix data,tks
  11. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    I put my simtools setting this way.
    so basically the axis 1 = roll, axis 2 = pitch, axis 3 = yaw ... and so on. And then now all you need to do is take those data to your motion seat control. (~^w^)~
    As you see axis1 symmetry with roll.
  12. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    You are It's Very Kind of You ,Thanks!!!:)
    I had try it ,it work.
    I found a bug,if i select "Binary" or "Hex" format ,I only get half data, (-100% -- 0% always get "0"),"Decimal" mode is OK.
    Thanks again!!!:thumbs
  13. kazhoang
    kazhoang Tai
    Student
    VietNam
    242Coins
    @DoThink
    Ha Ha I had that same problem before. Glad that i can help you, anyway I am on the way to make a real 6 dof. Hope servos control in my mini 6dof not so different from the motors control in the real one.
  14. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    Thanks a lot for your help.
    Wish you success:thumbs
