MY SIMULATOR IN MINIATURE
Discussion in 'DIY Motion Simulator Projects' started by luky_90, Mar 5, 2016.
  1. luky_90
    luky_90 Member
    276Coins
    hello guys, I'll post some photos of the new simulator that I built with engines 24v,at the end as I used the Pololu VNH5019 card, as you can see I have separated the 24v with potentiometer signals but still and disturbed and have no problems I had to set the dead zone to 14.I also would like to put the utility of video tips for a good setup !!
    @RufusDufus
  2. Saftari
    Saftari New Member
    Jakarta, Indonesia
    122Coins
    can you share the arduino code for modelling process here?
    153,764Coins
    +11,149 / 57 / -2
    As previously advised please start your own project thread here and post all your questions on it, do not post them on other member's build threads:
    http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Also as previously advised you will find many answers if you first look in the FAQs, including your current question: https://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
