Windows 10 Unhandled Exception
Discussion in 'SimTools DIY Version' started by Scotty1186, Oct 14, 2016.
  1. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    I have seen this error in a couple other posts, but everything that has been suggested in other posts has failed to remedy the issue. I am getting the unhandled exception error shown below in the image. I have also included the text. I have tried to uninstall/reinstall .net as well as activate and deactivate several combinations of windows settings. I have uninstalled and reinstalled Simtools and tried running as admin, but it is still coming up with this error. Any suggestions/lessons learned over the time Windows 10 has been out that I can try to get this working? For reference, I am only set up to use one system to control everything right now, as I haven't been able to get it running to change any settings.
    Here are images of what the interface looks like when I hit continue:
    152,099Coins
    +11,065 / 56 / -2
    Can you please post the full details for the error message.
    What .Net version is being used?
    I have SimTools running on Win10 on 3 different machines without any issues.
  3. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    System.Net.Sockets.SocketException (0x80004005): Only one usage of each socket address (protocol/network address/port) is normally permitted
    at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
    at System.Net.Sockets.Socket.Bind(EndPoint localEP)
    at System.Net.Sockets.TcpListener.Start(Int32 backlog)
    at SimTools_GameEngine.frm_GameEngine.Start_GameManagerGui_Server()
    at SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1586.0 built by: NETFXREL2
    SimTools_GameEngine
    Assembly Version: 0.1.3.0
    Win32 Version: 0.1.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.6.1586.0 built by: NETFXREL2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    152,099Coins
    +11,065 / 56 / -2
    What else is running that could cause a port conflict on your machine?
  5. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Its an Asus laptop, so its possible that there is some pre-installed junk running on it. Ill shut a few more things down and check again. I am also running McAfee total protection. Do you think that might be causing problems?
    152,099Coins
    +11,065 / 56 / -2
    Yes I expect something running is causing the conflict and shutting down McAfee would be a good place to start.
  7. value1
    15,031Coins
    What game are you running?
  8. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    I am not currently running any games. Still trying to connect everything and set up the motors.
  9. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    I believe I got it figured out. I had to make a registry edit to set the maxuseports to 50,000 instead of the default 4000. This must have been enough to free up enough dynamic ports to let me operate. On to the next step of inevitable failure!
    As always, thanks for the help :)
    152,099Coins
    +11,065 / 56 / -2
    I am a bit strict about what auto starts and what runs in the background on my machines, both for performance and security reasons, and it sounds like you should do the same.
  11. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Yeah this one is only about 2 weeks old and I didn't have a chance to clean it up yet. Nice little laptop but it was an emergency purchase from best buy. I went through the msconfig last night and shut about 30 things off.
