Wanted-Pedal Set universal bolt slot template
Discussion in 'DIY Motion Simulator Projects' started by BlazinH, Oct 15, 2016.
  1. BlazinH
    16,689Coins
    I’m making a base for my Logitech G27 pedals to bolt to. I’m using slots in the base so the pedals can be shifted right or left of center if desired. But before I paint it I would like to add slots for pedals from other manufactures like Thrustmaster and Fanatec because at some point down the road I may use them. But I don’t own any other pedals and I was not able to find any bolt templates other than for Logitech pedals online.
    Has anyone run across a universal template for pedal bolts? If not, do you have any photos of the bottom sides of your non-Logitech pedals you can share along with the bolt spacing measurements? Thanks.
    153,728Coins
  3. BlazinH
    16,689Coins
    Thanks @noorbeast. I read that Thrustmaster only uses 2 bolts so now I just need to find out if they are positioned half way between the front and the back or offset one way or the other.
  4. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
  5. BlazinH
    16,689Coins
