Bug Problem Game Data Input Assetto Corsa
Discussion in 'SimTools DIY Version' started by Thierry1401, Oct 16, 2016.
  1. Thierry1401
    Thierry1401 New Member Gold Contributor
    Technician
    Belgium
    54Coins
    SCN6, 4DOF
    Hello, here is my problem:
    All worked well until the updated Windows 10 on 4 October.
    The computer rebooted when I threw Simtools and Assetto Corsa!
    I reformatted and reinstalled without any updates Windows 10.
    Installing Simtools V1.3 is OK.
    I have put the plugin for AC 3.0.6.0. in Game Manager and I put 127.0.0.1 IP setting.
    I patched D: \ Steam \ steamapps \ common \ Assetto Corsa
    In Game Engine, I make Axis assigment and interface setting
    I use Output Testing and 4 SCN6 work (DOF and Axis outputs).
    So I run Assetto Corsa 1.8.1 and SCN6 do not move!
    I check in Tuning Center game data verry little move! Only a few units or tenths of units.
    They should move up to + and - 32767?
    In Game Engine Output Testing Virtual Axis very little move not more!
    So SCN6 do not move!
    Anyone has had this problem?
    Thank you in advance for helping me.
    153,764Coins
    +11,149 / 57 / -2
  3. Willem Pienaar
    Willem Pienaar New Member
    478Coins
    Although this is my 1st install of the Assetto Corsa plugin, I'm experiencing a very similar problem in that Assetto Corsa to start SimTools. I've downloaded the AC plugin and patched the game successfully. I have started AC from within Steam and from the shortcut on my desktop, but all to no avail.
    P.S. SimTools plugins for iRacing, FSX, X-Plane and various Stem Games (Eurotruck, PCars and Dit Rally) all works fine.
    I'm also running the latest Anniversary edition of Windows 10 (but it does not affect any of the other plugins)
    Note : SimConnect is usually locked when you're in a game i.e. don't allow you to make any adjustments. In the case with AC Simconnect is not locked. It does not appear as if there is a connection as no live data gets transmitted whilst I'm driving.
    What am I missing.
    Any suggestions will be appreciated.
    Regards
    Will
    153,764Coins
    +11,149 / 57 / -2
    Please don't post the same issue to different threads, it is too hard for members to follow.
    I already asked to please post pictures of all your settings here: https://www.xsimulator.net/community/threads/assetto-corsa-plugin.4921/page-7#post-115976
  5. Thierry1401
    Technician
    Belgium
    54Coins
    SCN6, 4DOF
    Thank you @noorbeast
    I'll watch it all. I will keep you informed.
  6. Thierry1401
    Technician
    Belgium
    54Coins
    SCN6, 4DOF
  7. Thierry1401
    Technician
    Belgium
    54Coins
    SCN6, 4DOF
    Thanks @noorbeast
    In Tuning Center, when AC plays, I did this:
    1. Press the Capture Max Min button.
    2. Press the Reset button. (Clears the current settings – step not shown)
    3. Drive around the track carefully not to bump walls or hit anything that will skew the results. You should see the new Max/Min values being captured in the Tuning Center window.
    4. Click pause on the game, if you want to alter any of the setting by hand now is the time to do it.
    5. When you are happy with your new settings click the Save New Settings button. And the new Max Min will be applied live while the game is running.
    6. Press Stop Capture if you are finished altering the Max/Min limits.
      Now SCN6 move well! I hope this will help solve your problem too @Willem Pienaar
      Thank you all. Best regards.
    153,764Coins
    +11,149 / 57 / -2
  9. Thierry1401
    Technician
    Belgium
    54Coins
    SCN6, 4DOF
    I understood well. I will do it when my frame is completed.
    For now I'm testing the SCN6 actuators movements in space.
    I'll post some pictures when it is finished.
  10. Willem Pienaar
    478Coins
    Must have been doing something wrong initially. I spent some time last night verifying all my settings and re-installing the plugins. I fired-up Assetto Corsa and lo and behold my seat came alive when joining a session.
    I am well chuffed thank you.
    Regards
    Will
