Tutorial How to Modify a Server Power Supply for 12v
Discussion in 'DIY peripherals' started by Slider, Sep 7, 2014.
  1. noorbeast
    153,710Coins
  2. Shadow041
    Shadow041 New Member
    Sparkie
    Melbourne, Australia
    431Coins
    Awesome, ill give that a shot. I did try to limit the current in the jrk utility program but it didnt seem to make much difference...
    what didnt make sense was how the jrk could be overdrawing the PSU when there is a 17A difference between the max of what the jrk can handle and the output of the PSU...
  3. bsft
    Server PSUs are sold cheap because they are at the end of their service life and generally do not like big spikes in current being drawn.
    Id suggest splash out the cash and invest in some NEW LED power supplies. http://www.ebay.com.au/itm/500W-DC-...ower-Supply-/371380627897?hash=item567802a9b9
    they really do handle big spikes of current.
    And as Noorbeast said, please share screen shots of ALL the JRK utility tabs so we can check settings.
  4. Nick Moxley
    PSU shut down's are largely in part to improper setting's on JRK/PID/Game engine settings, Yes a PSU can be "bad" but imo these server PSU's have Far better components in them when comparing to the 100$ Chinese knock offs.
    Look at the retail price of a Dell Server PSU, You might be in for a Surprise.
  5. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I suffer the same issue. Only one does it. Motors are new, they are 60:1, using 2 psu, Only happens on the one side. I have a 2950 60a 750watt on the way, be here Friday. Gonna use that for both instead. THat should be way more power then I need.
  6. bsft
    • Old Old x 1
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Im assuming yes, I found a few on amazon of the same rating for 49$ us. I was hoping to find something with 60+a so I can run 3 units off of the supply.
  9. bsft
    No, One per motor.
  10. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    you can make your arduino work on 31khz and scream disapears but be careful with your h-bridge to be able do this
  11. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    124Coins
    Haha LoL this setup generates more amp than my welder! Rectifier between you can weld. This very pretty. Well done! I immediately go find server power supplies for my sim!
  12. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    I just got my HP DPS-600PB B and when i plug it in the fan comes on without any connections to the pins. Is this normal?
    With the pins shorted i don't seem to get any change and no LED power light, although the fans are spinning.
  13. PiaMan
    607Coins
    never mind.... further testing revealed a bad connection in my dupont cable.
    Fan still comes on and stays on though but i can turn on the supply and get 12.5V
    153,710Coins
    Yes the fan running is normal.
  15. Musashi
    Musashi New Member
    Composer
    Nashville, TN
    339Coins
    OMG...this is rather an AWESOME tutorial THANK YOU!!
  16. Guilherme Correia
    Guilherme Correia New Member
    165Coins
    boa noite, uma pergunta simples, comprei uma fonte dsp-600 pb, soldei as duas saídas positivas em um cabo e fiz o mesmo com o outro. Porém, não houve sinal de energia no MM, o cooler da fonte funciona normalmente (irei testar com o multímetro amanhã). Gostaria de saber de os pinos no centro, obrigatoriamente devem ser usados. Grato.
    good night, a simple question, I bought a dsp-600 bp source, soldered the two positive outputs in a cable and did the same with the other. However, there was no power signal in MM, the cooler the source works normally (I will test with the multimeter tomorrow). I would like to know the pins in the center, they should necessarily be used. Grateful.
  17. minanke
    minanke New Member Gold Contributor
    Developer
    Hong Kong
    - 374Coins
    yes, you need to connect those pins like showing in post #1
  18. Guilherme Correia
    165Coins
    i try tommorow, tks
  19. Guilherme Correia
    165Coins
    funcionou, obrigado.
    worked, thank you.
  20. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    I'm trying to modify 2 HP DPS600 to use with only one Switch. Can this schema works?
    I think yes, because I've connect together both 4&8 pin and 6&10 pin of 2 psu.
