IL-2 Cliffs of Dover Inspirational Videos
Discussion in 'Other Flight Simulation Games' started by Historiker, Apr 13, 2016.
  1. Historiker
    9,205Coins
    I just started flying with this group based on these videos. Absolutely incredible battles with 150+ real pilots cycling through the server for scripted historic air battles from the battle of France to the Battle of Britain.
    It blows your mind to take off at the same time as 15 other pilots in your Staffel while three other Staffels are queing up on the same air field to do the same!
    153,920Coins
    +11,156 / 57 / -2
    Great game play!
    I have setup COD for my father, he is still practicing offline at the moment.
    If they do integrate the VR support they are working on then you can count me in.
  3. Historiker
    9,205Coins
    They fly every Sunday at 1900 GMT. I was surprised to find that they had not exaggerated their turnout a bit. I have never seen a teamspeak so full, nor a flight sim server that busy.
    I managed to survive our sortie and although I never fired a shot I did manager to get several hits on the nose of a Hurricane with pieces of my tail and wing!! :cool:
  4. Nathan Older
    Nathan Older Member
    211Coins
    Hi Guys, not sure where to ask this, but I have a copy of IL2 1946, is this plugin on this site compatible with my game ?
    just thought id give it a try with my simulator some time.
  5. Historiker
    9,205Coins
  6. Nathan Older
    Nathan Older Member
    211Coins
    Oh Great. Thank you so much! yet again, very helpful people who reply very quick.
    Much appreciated
  7. Nathan Older
    Nathan Older Member
    211Coins
    Not sure what i am doing wrong, but i have installed the plugin on both computers and patched the game in game manager. When i stat the game up i dont get any movement and nothing moves in the virtual axis either.
    Been playing rFactor and Race07 fine today, but nothing working from IL-2
  8. Historiker
    9,205Coins
    @Nathan Older the link that I posted above would be a better place to ask for help with the plugin. I would recommend that you first read through the thread as someone might already have had and solved the issue in a previous post. Good luck with you project.
  9. Nathan Older
    Nathan Older Member
    211Coins
    Will do, thanks
