Tutorial 12cm 12V 7segments gear indicator with GameDash
Discussion in 'DIY peripherals' started by RacingMat, Aug 30, 2014.
  1. value1
    14,175Coins
    Cool cool-skype.png Thank you @Matth.Gyver!
    Go through the plugins list and collect what you find there.
    We still can add undocumented dash data afterwards.
    :thumbs
  2. RacingMat
    21,066Coins
    Hi Nick! It's detailed into the first topic: you will find what kind of arduino is needed and 2 links with the lowest cost supliers I found :)
    Thanks Matt!
  3. Matth.Gyver
    Matth.Gyver New Member
    208Coins
    Ok gentlemen driver, so there is the sorted list of the plugin compatibility (from the plugin page) :
    Maybe a dedicaced topic or other place will be most adapted no ?
    - Asseto Corsa Plugin 3.0.6.0
    -Speed [km/h], RPM,Gear, Shift, Light, Fuel[lt], Fuel [%], Car model, Track name
    - DTM Experience Demo Plugin 1.0.0.1
    - RPM, Max RPM, Fuel Pressure, Fuel, FuelCapacity, Water Temp, Engine Oil Temp, Oil Pressure, Speed, # of Laps, Completed Laps, Best Lap Time, Previous Lap Time, Current Lap Time, Position, # of Cars, Gear, Shift Light
    - Formula Truck 2013 Plugin 3.0.0.5
    -Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp, Fuel, Fuel %, Headlights, Engine Overheating, Brake Overheating, TireDamage, ShiftUp, ShiftDown, PartsDetached, InPit, YellowFlagState, GamePhase, Flags 1. Sector, Flags 2. Sector, Flags 3. Sector.
    - Game Stock Car Plugin 3.0.0.3
    - Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp, Fuel, Engine Overheating, Brake Overheating, TireDamage, ShiftUp, ShiftDown, PartsDetached, InPit, YellowFlagState, GamePhase, Flags 1. Sector, Flags 2. Sector, Flags 3. Sector.
    - GP Bikes Plugin 3.0.0.1
    -Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp Fuel, Fuel [%], Engine Overheating, ShiftUp, ShiftDown, In pit
    - GT Legends Plugin 3.0.0.1[/B]
    - Speed, RPM, Gear, Actual Fuel Pressure, Fuel Litres, Fuel Capacity, Engine Water Temp, Engine Oil Temp, Engine Oil Pressure, Lap, Best Lap Time, Previous Lap Time, Current Lap Time, Position, # of Cars in Race
    - GTR Plugin 3.0.0.1
    -Speed, RPM, Gear, Actual Fuel Pressure, Fuel Litres, Fuel Capacity, Engine Water Temp, Engine Oil Temp, Engine Oil Pressure, Lap, Best Lap Time, Previous Lap Time, Current Lap Time, Position, # of Cars in Race
    - IL-2 Sturmovik: Cliffs of Dover Plugin 3.0.0.9
    -Speed, RPM, Roll, Pitch, Yaw, Altitude and Climb
    - IL-2 Sturmovik: Forgotten Battles Plugin 3.0.0.8
    -Speed, Turn, Roll, Pitch, Yaw, Altitude and Climb
    - KartRacing Pro Plugin 3.0.0.1
    - Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp, Fuel, Fuel %, Engine Overheating, ShiftUp, ShiftDown
    - RaceRoom The Game 2 Plugin 3.0.0.1
    - rFactor plugin 3.0.4.0
    -Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp, Fuel, Engine Overheating, Brake Overheating, TireDamage, ShiftUp, ShiftDown, PartsDetached, InPit, YellowFlagState, GamePhase, Flags 1. Sector, Flags 2. Sector, Flags 3. Sector.
    - rFactor2 Plugin 3.0.6.0
    - Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp, Fuel, Fuel %, Headlights, Engine Overheating, Brake Overheating, TireDamage, ShiftUp, ShiftDown, PartsDetached, InPit, YellowFlagState, GamePhase, Flags 1. Sector, Flags 2. Sector, Flags 3. Sector.
    - Richard Burns Rally (SSE) plugin 3.0.0.3
    - Speed, RPM, GEAR
    - World Racing Series Plugin 3.0.0.1
    - Speed, RPM, Gear, EngineWaterTemp, EngineOilTemp Fuel, Fuel [%], Engine Overheating, ShiftUp, ShiftDown, In pit​
  4. RacingMat
    21,066Coins
  5. RacingMat
    21,066Coins
  6. Matth.Gyver
    208Coins
    Thank's RacingMat
    I hope you could publish in table format because actually it's not very lisible :-\
    I wanted make an html table but the forum does'nt accept html code.
    Otherwise, you can't put the link in the faq ?
    How give you the writte access to the faq ? If I have this access I could do the update.
  7. RacingMat
    21,066Coins
    Let's wait for the answer from the administrator RaceRay!
    Sorry, FAQ edition access is restricted by administrator (edition allows accidental deletion...)
  8. Matth.Gyver
    208Coins
    I found a 3inch 12v display in my stock but it's common cathode .
    It seem to be more complicated to drive it (mainly because it is 12v, there is a driver for 5V, not for 12)
    Maybe anyone have a solution ?
  9. RacingMat
    21,066Coins
    Common cathode will require to source current rather than sink it... You will have to find anoter chip reference. Or maybe someone could advise you (as I have no computer access this week)
    As 4" is better than 3" ;-) you could order a 4" common anode :p
  10. Matth.Gyver
    208Coins
    I think that I'll buy a new one, it will be more simple.
    I've tested a free Android application for RBR allowing to display only gear indicator.
    On my old nexus 3 phone the size is approximately the same of my 3 inch 7 segments and I found the size correct.
    I'm affraid that a 4 inch will be too big
  11. RacingMat
    21,066Coins
    @Cluclu : you'll find some answers here hopefully for your "8 digits and 8 leds" project and how GameDash is communicating with a Dashboard
  12. stamer57
    stamer57 Member
    963Coins
    Beau travail
  13. Lele411
    Lele411 New Member
    Gala
    198Coins
    Good Job. Thanks to share the projects!
  14. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    Nice On,
    I build this one & it´s great but i can not download plugins to test :)
  15. RacingMat
    21,066Coins
    Thanks! :)
    Please share some pictures of your work! I would be very pleased to see them :popcorn I could give you some coins ;)
  16. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    I will share some Pics when i am at Home
  17. Nick Moxley
    Oh how i wish i knew how to read a schematic and build little circuits like this. One day maybe. :think
  18. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    No Problem, maybe i can help you a little with shematic but not with programming :)
  19. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    Ok here some Pics
  20. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    Only write me for help
