3 DOF DCS Oculus Rift motion platform project
Discussion in 'DIY Motion Simulator Projects' started by dureiken, Oct 17, 2016.
  1. dureiken
    dureiken Active Member
    1,248Coins
    Hi there,
    just starting a new thread, to have some help and to help further simmers :)
    The wish
    1-Use with Oculus Rift, mainly for DCS sim
    2-Use AC motors
    3-Add a g-seat seat next year if possible !
    Starting the project (2016-10-17)
    Motor : 3*1.1KW AC 23rpm 311Nm, used on 120° not 180°
    Lever : 20cm which means +/- 17.5cm for 120°
    Angle : 17°
    Linear speed : 0.3m/s minimum
    Acceleration : 2g minimum
    My first drawing (it's really bad compared to others xsimers but it's just to make good choices for design and kinetics) :
    I have 3 big questions before going on my project :
    1-Am I in the good way/choices ? :)
    2- I'm really hesitating between these 2 motors/levers lenght
    they have near the same linear speed and momentum, but one will have 16cm for heave, the other 35cm
    the first one will have 749W and the second one 903W for both 1.1kW input.
    For 18° angle, pivot points with 8 cm lever
    and 20cm lever
    3-what will be the current during the use of motors ? because it's 6time higher at starting, which makes 86A ???
    Will there be at all time 86A because motors are always changing direction ??
    Thanks a lot !!
  2. dureiken
    1,248Coins
  3. dureiken
    1,248Coins
  4. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    position on motros like your
    after one year. start change chair for this .
    It still is working on it
  5. dureiken
    1,248Coins
    sounds awesome ! how does it feel ? motion brings a lot of immersion with VR ?
    just add some design with my motors/levers question :)
    thanks
  6. dureiken
    1,248Coins
  7. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Sounds great ideas ...
    How can I help ?
  8. dureiken
    1,248Coins
    Thanks.
    I asked some questions on Fp. Specially about intensity
  9. sasystem
    sasystem New Member
    Metal Worker
    Spain
    367Coins
    I'm new here but surely they'll tell you 23rpm is very slow. :nerd
  10. speedy
    Alexandria , Egypt
    7,948Coins
    Motors current will be written on the motor's name plate and for a [ 1.5HP=1.1KW ] AC motor it will never exceed 3-4 Amps
    when using VFD inverters it will be programmed to give you an S curve for holding a constant torque while forward/reverse/low RPM ... and it will automatically maintain the motor current for not overheating or damaging its coils ...
  11. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    other than the expense, I love my AC setup...........
    With my friend @speedy helping me immensely, my motors work just great and after an hour's use, are barely warm.
    Tom
  12. BlazinH
    16,689Coins
    For comparison purposes I use 600watt 12vdc motors and at stall they pull 135amps each. In usage though my clamp meter that has a hold function shows a max draw of 90amps. Mine are 68rpm though.
  13. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    im running 6x 1.1kw AC each through its own 20amp MCB which then all goes through a 40amp RCD.
    No problems with tripping yet.
    the max current on the motor plate is the 3phase current, if you have single phase going into the inverter then as a rough guide you can say it will pull 3 x as much at the single phase side during stall.
    TBH if your motors are stalling then theres something seriously wrong with the platform, you should never get close to that.
    The first motor you listed has way more torque which you will need depending on the weight of the platform/cockpit you plan to use, if you are going to use the platform mainly for flight sims then the speed will be fine.
    personally if i was starting a build now id be looking at the linear actuator route that others here are taking. Cuts out the gears and VFD's. You get direct drive linear motion which is going to be more responsive and more detailed.... and its cheaper!
  14. dureiken
    1,248Coins
    why it would be very slow ? it just depends on the lever length for linear speed ?
    ok thanks :)
    where is your project ? :) to compare and take some ideas
    do you have good links for linear ?
    I won't have cockpit, just Oculus Rift and hotas, maybe a gseat after. I go with 150kg pltaform, and acceleration is given with this weight in table in FP.
    What is MCB and RCD ?
    BTW thanks all for replaying :)
  15. paulg100
    Bristol UK
    1,373Coins
    MCB: miniature circuit breaker
    RCD: residual current device
    "do you have good links for linear"
    all the projects are on here
  16. speedy
    Alexandria , Egypt
    7,948Coins
    Feeling sorry for you adopting this DC amps. HUGRY beast ...
  17. speedy
    Alexandria , Egypt
    7,948Coins
    It is really easy @dureiken to reverse calculate the max rpm required on the gearbox shaft ...
    For ex. If you want at any point of a 3DOF 1m. Equal sides Triangle base a linear speed of 30cm/sec. and a travilling distance of 20cm up and down ...
    1- You'll use a 10cm CTC "center to center" crank arm lever that will rotat a 180 degree to get the 20cm up/down displacement ...
    2- then caculate everything normally and multiply the resulting rpm by 1.5 to get the 30 cm/ sec. linear speed ...
    So ...
    [ 180deg./sec * 2 ] = 1 revolution/ 2sec = 15 revolution / minute
    The min. required RPM will be = 1.5 * 15 = 22.5 RPM
  18. dureiken
    1,248Coins
    Yes thanks but why are you talking about this ? my first table shows all these calculs, for different levers and 120° rotation of gearbox (not 180)
  19. speedy
    Alexandria , Egypt
    7,948Coins
    Yes sure I saw that :) ... but you just didn't explain how you got these values ??? ... and it felt like it has been copied and you're not sure af what you need .
    More detailes are always welcomed .:cheers
  20. dureiken
    1,248Coins
    They are not copied from anywhere, just made by myself
    I took an angle of 120° not 180° for full amplitude on a motor, and I used different lever lenght to found linear speed and acceleration.
