3dof seat mover 360 degrees traction loss/yaw
Discussion in 'DIY Motion Simulator Projects' started by hartsa90, Sep 21, 2016.
  1. hartsa90
    hartsa90 Member
    Finland
    111Coins
    I was thinking of opening a thread later on but I need advice (new member) before I do something irreversible.
    Hopefully haven't done already.
    So here's my plan so far: 3dof racing simulator with 360 traction loss/yaw based on RacingMat's 4dof 1 pin code. Simulator would be similar to (FAQ section innovative idea) 360 yaw simulator. The rig would be placed on three wheels. Two on the front and one the back of the seat. It would be a seat mover and the motors would be placed on front of the seat. Seat would be moved with a linkage system. I was thinking of using "dog bones" from a car stabilizer bar to keep the noise down. Traction loss/yaw motor will be attached to a wheel (diameter 270mm). Motors would be Nidec worm gear motors 24v 6A 70rpm 46:1.
    Already bought Arduino Uno and three Pololu G2 24V21 motor drivers. Need to buy three 24v 200w PSU's. I have three 10 turn 10k pot's which would be attached to the motor's with gears. Have been reading other threads and to me it seems that I could get better resolution with 10 turn pot's? Also I have a slew sensor with continues pot for the traction loss if that can be used?
    I haven't found information about traction loss wash out feel. Do you notice the wash out if the rig has fixed bearing on the font of the rig?
    Thank's in advance...
    EDIT:
    Changed my configuration to SMC3 utility for better motor controll.
    Here's a Dirt Rally video of the sim in action.
  2. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Little change to my plans. I have two unused Speed 900bb torque motors which I will equip with 1:6,25 planetary gear and 3M HTD timing belt system. It will give total ratio of 1:81. Motor no load speed is 6500 rpm at 12V 1.1A and I am going to run those with 24V. Hopefully my math is correct: 6500/81=80rpm so 80/60x3,14x50=209 mm/s linear speed for the seat mover.
  3. Nick Moxley
    360deg is NOT traction loss, Its Yaw. More to do with Flight than with Racing.
  4. hartsa90
    hartsa90 Member
    Finland
    111Coins
    I am trying to manufacture traction loss without wash out. Same Pivot point as traction loss rigs have. If somebody could give their opinion about the wash out feel. Is it notiaceable of not?
  5. Pit
    30,497Coins
    It is. To me it is more noticeable than my sway table...which means a lot. If you use a 360° TL motion design you should use washout for sure, washout lets you feel more real, otherwise the TL motors are snapping back to start position which is not always coherent to the car in the game.
  6. hartsa90
    hartsa90 Member
    Finland
    111Coins
    OK thanks. It seems that I got it backwards. When you use washout the motor will not Center itself. That Is what I was looking for, real movements only...
  7. hartsa90
    hartsa90 Member
    Finland
    111Coins
    I will Post Pictures of My actuators as soon as I am allowed to. Just did a quick test with a lab psu. Actuators seems to work. Motors and the planetary Gear seems noisy.
    I have to insert a limit switch to cut the motor Power in Case of motor run away. Also potentiometer Must be mounted to the motor shaft.
  8. hartsa90
    hartsa90 Member
    Finland
    111Coins
  9. Nick Moxley
    Interested, But very confused at the same time. Look forward to your next updates.
  10. hartsa90
    hartsa90 Member
    Finland
    111Coins
  11. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Here's my electric schematics. PRW3, DIR3 and pot3 pinouts missing at this point.
    Going to use hall sensors for the seat mover motors and 10 turn pot for the traction loss.
  12. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Wiring almost done... Here's a picture of the pololu drivers.
  13. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Made some progress on the build.
  14. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Are you going triple screens?
    That rig's gonna flex/shake A LOT. It seems a bit too thin to me
  15. Nick Moxley
    I would also echo Blame's worries....when the rig gets oscillating, it will surely transmit some of that up to the Monitor stand.....Beef up or build some legs for the monitor and have them independent of the rig itself.
  16. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Yep need to add vertical supports and hopefully it will be sufficient...
    Back to the drawing board if it will not hold.
  17. hartsa90
    hartsa90 Member
    Finland
    111Coins
    It takes ages to get the parts done...
  18. hartsa90
    hartsa90 Member
    Finland
    111Coins
    At least something done. Feels guite strudy now...
  19. Nick Moxley
    Wow, Ill be amazed to see those weee little motor's actually pull this off..Seriously looking forward to seeing them move for the first time......And Kill switch underneath the seat ? Whats that for ? Wheel or Motion ...i see you have another on the Dashboard too.
  20. cfischer
    Colorado
    2,783Coins
    Looking forward to how you're going to implement 360 traction loss. I don't think sim tools is even setup to not return to center for traction loss.
    Back in October @Pit was saying that washout is much a much better way to get to center than without. Either way traction loss will return to center. But you are saying that you will never return to center. I could be wrong but I don't think anybody has ever done it. You are going to need a huge space too because the length of your rig would be the radius of the circle traveled instead of the diameter in 360 yaw. I pictured this thing getting put together in a warehouse or something.
