Showroom Budget Steel 6dof w/ MM (Now Sabertooth 2X60), Arduino, Chinese 12v Motors
Discussion in 'DIY Motion Simulator Projects' started by CLEOPHUS, Sep 3, 2016.
  1. noorbeast
    152,445Coins
    +11,077 / 56 / -2
    Well you said you were done with motion projects for a while...but you can always change your mind!
  2. Pastrana
    Pastrana Member
    Argentina
    165Coins
    complicated very good project not?
  3. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    :D I'm consumed by VR at the moment, so my Sim does the job for me.
    6 DOF is so appealing for Heave though!
  4. 1oldbiker
    1oldbiker Member
    281Coins
    I have been following this build. I do so want a 6dof sim. Good job on the build.
  5. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    I bought the same motor, how you connect the wire to motor?
  6. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    @Racing Mike you can use this (cant remember what they are called in english:oops:)
    or you can solder a wire directly on the motor.
  7. cyril69850
    cyril69850 New Member
    293Coins
    I'm really looking foward to your work. Your built is the most impressive with this budget motor.
    Keep up with your big toy!
  8. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Early test with Dirt Rally. (My 11 year old driving)
    • Like Like x 7
    • Winner Winner x 5
  9. obobo
    obobo Active Member
    1,323Coins
    very impressive
    But off budget for at least 4 or 5 years
  10. CLEOPHUS
    CLEOPHUS Member
    229Coins
    I missed this question. I wondered the same and ended up just soldering 8-gauge wire directly to the motor terminals. I removed the rubber insulators from the motors and then taped over the connections with a real thick electrical tape. Use a ton of flux and preheat both.
  11. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Another test video.
    • Like Like x 5
  12. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    You get the awesome dad award for the week!
  13. CLEOPHUS
    CLEOPHUS Member
    229Coins
    haha! I enjoy it way more than him - but you won't see videos of me. I love using Assetto Corsa on it but don't have a ton of time.
  14. obobo
    obobo Active Member
    1,323Coins
    This is unfortunately the case for many of us:mad::mad:
  15. SilentChill
    20,593Coins
    Looking really good :thumbs well done
    Dirt Rally looked really ruff great stuff
    How's ya motors coping with heat have you had any issues ?
  16. mayhem
    mayhem Cobra Commander
    IT
    555Coins
    Great build CLEOPHUS,
    I had a few questions as I haven't touched a build anything close to this before and I'm very curious.
    • In your original post you had your parts list, looks like the ebay coolers for the MM link is the same as the MM themselves. Can you provide a link to the coolers?
    • What kind of arduinos did you use? How much did these run, or did you just have them around already?
    • How long did you cut your threaded rod? Did you just go with a rule of thumb and then adjust it in? You mentioned calibrating them, what was the process for doing that?
    • What were some of the software settings you eventually used and became happy with?
    Apologies for all the questions at once, but so much to learn.
  17. CLEOPHUS
    CLEOPHUS Member
    229Coins
    I wish I had a great story to tell on how I drew up schematics and tested everything before the build - but I just winged it and hoped for the best.
    - Here is the correct link for the coolers - HERE I will update the post.
    - I bought the arduinos at MicroCenter - HERE $5.99 USD each
    - I didn't cut the threaded rod. I ordered the 24" length and hoped I wouldn't need to cut it. With the original orientation I thought I might need to cut them because it was very unstable, but in the end they worked great.
    - I would be happy to post screenshots of them settings in simtools. I'm not in front of that PC now but could post some this weekend.
    Let me know if you have any other questions.
    Cliff
  18. CLEOPHUS
    CLEOPHUS Member
    229Coins
    So far - everything has been great with no overheating, even with me on it (180 lbs). I was hoping I wouldn't need to mount fans on the motors like you did, and so far we have been OK. I would say they are warm to the touch - but nothing more than that. I do only have PWMmax set at 150 in SMCutils because of all the documented MM issues.
    My son complains that Dirt is too ruff and I say suck it up. haha
    I still would like to add a USB on-off main switch on the rig and a seat belt. The handbrake is really fun in Dirt, and with the traction loss dialed in, you really get the feel of driving.
    I see you gave up on the MMs for your new build?
  19. SilentChill
    20,593Coins
    Good to hear the motors are not overheating and by the looks of it you dont really need anymore power to the motors as it looks really responsive as it is :)
    Yes I gave up in the end last 6 I bought only 1 worked all the others were duds so went with the sabertooths . Still got lots of problems but I will get it all sorted eventually (I hope :D)
  20. mayhem
    IT
    555Coins
    Much appreciated!
    I'll be sure to ask if I come up with anything else to ask, but I'm also a bit of a "wing it and hope for the best" type.
