What are potentiometers used for?
Discussion in 'DIY Motion Simulator Projects' started by Deleted member 23415, Nov 4, 2016.
  1. Deleted member 23415
    Hello everybody,
    My dad and I want to build a motion simulator but have little to no experience with this type of "engineering".
    Most of the things we found out mainly by research and help from @noorbeast but there are still some things that remain unclear.
    Potentiometers.
    What are they for, which ones are good and how do I mount them.
    Thanks in advance, Mathis.
  2. SeatTime
    Pots are required for positional Feedback - basically to turn a standard motor into a 'Servo' motor https://en.wikipedia.org/wiki/Servomotor. What type/how to mount - depends on what type of sim you are building - Have a look in the project area - plenty of examples.
    152,099Coins
    +11,065 / 56 / -2
  4. value1
    15,031Coins
    I also strongly recommend hall effect sensors, e.g. from Farnell. They are much more accurate, more sensitive and quicker than conventional carbon potentiometers. Replacing the carbon pots with Hall sensors was a leap-frog of the quality of the movement on my sim!
    See also this thread.
  5. erik1992
    erik1992 NONE
    Student
    Saltillo
    124Coins
    there are some kind of potentiometers which are called "precision potentiometer" they are very accuarate. they are better, try them
  6. sasystem
    sasystem New Member
    Metal Worker
    Spain
    367Coins
    Hall DIY example
  7. Deleted member 23415
